September 02, 2026, 01:34:49 PM
Pages: « First < Previous 1 ... 567 568 [569] 570 571 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3689116 times)
0 Members and 13 Guests are viewing this topic.
« Reply #8520 on: March 12, 2016, 03:34:12 PM »
Accord is mostly fixed and back up and running.
The crv needa a new alternator lol life sucks balls hard
« Reply #8521 on: March 12, 2016, 09:35:42 PM »
Pulled apart an old transmission today to get 6th gear off of it. My 6th gear let go last night when I was driving around.
« Reply #8522 on: March 13, 2016, 06:40:43 PM »
Car's still at the shop. No updates/info yet.
« Reply #8523 on: March 14, 2016, 05:22:57 PM »
Started my brake overhaul/upgrade yesterday.
« Reply #8524 on: March 16, 2016, 12:13:12 AM »
found out that the CRV driver axle has a torn boot. Also getting a lot of popping and clicking noise. I hope it not the ball joint... or as Tim calls it "Male child birth" round 4
« Reply #8525 on: March 17, 2016, 03:21:21 PM »
Did a valve adjustment and leak down test the other day.  Everything checks out with only 2%-7% leak between all the cylinders.  Pulled the blower off yesterday to look for possible coolant leaks and found nothing.  Pressure testing the coolant system comes up with a slow leak, but I can't find the source.  My guess is that it's from the radiator cap flange.  Time to pull this radiator and replace it with something better.
Getting ready to pull the motor out today.
« Reply #8526 on: March 17, 2016, 06:01:37 PM »
Completed the front half of my brakes. That's where the upgrade was. Stepped up to 08 CR-V calipers and TSX rotors. Had to do some modding for it to bolt on but night and day difference over the shitty OEM brakes. Slightly increased pedal travel over stock, barks my tires if I stomp on them and since the pistons are equal diameter, no need to flip them to bleed like the Legend calipers. Still need to redo my rear brakes.
SilverAccords06n12
SilverAccords06n12 pfffft.
« Reply #8527 on: March 18, 2016, 04:23:54 PM »
Finally taking off my Michelin snow tires despite snow in the forecast for Monday!  I also might try to sand the rust off two sets of steelies, and repaint them.  I can't decide between colors to go with my Alabaster Silver paint.  I'll probably just settle for regular old gloss black.
« Reply #8528 on: March 18, 2016, 08:35:50 PM »
Nice! Adding this to the to-do-list
Replaced brakelight bulbs, a whole 2mins Wink
« Reply #8529 on: March 18, 2016, 11:56:37 PM »
Rich, if you do plan on doing this take this into consideration: http://www.driveaccord.net/forums/4982330-post28.html
That's my reply in this thread: http://www.driveaccord.net/forums/178-wheels-suspension-brakes/45355-cr-v-dual-calipers-installed.html
« Reply #8530 on: March 20, 2016, 01:13:35 PM »
Thanks, i'll reference that when the time comes
« Reply #8531 on: March 20, 2016, 09:00:35 PM »
I changed my rear drums today. If I haven't said before that I hate drum brakes, I'm definitely saying it now. Next time I have to take anything apart back there, it'll be to swap to discs.
« Reply #8532 on: March 20, 2016, 09:16:16 PM »
Be grateful that you don't have to replace wheel bearings every time you do your brakes.  Cheesy
« Reply #8533 on: March 21, 2016, 09:03:11 PM »
Fuck that.
« Reply #8534 on: March 22, 2016, 01:13:35 AM »
That's what I have to do with the Civic.
Anyway, back on topic.  I drained the radiator and pulled it out.  I test fit my new Koyo radiator and it should be an easy fit.  Just a few small modifications and it will be ready to go.  I also drained the transmission, pulled the axles and removed the charge harness.  The motor is coming out again and the head is coming off for some machine work.  Gotta make a few upgrades to handle the increased flow that this blower is capable of.  Tons of fun.
Pages: « First < Previous 1 ... 567 568 [569] 570 571 ... 596 Next > Last »   Go Up
