November 06, 2026, 10:15:18 PM
555
556
557
558
Topic: What did you do to your Gen7 today? (Read 3817562 times)
Reply #8325 on:
May 30, 2015, 08:57:23 AM »
Revised the routing of my water lines in my water to air system. Hopefully this works better.
Reply #8326 on:
May 30, 2015, 11:28:22 AM »
Replaced timing belt, tensioner, water pump, lower control arm bushings and alignment.
Reply #8327 on:
May 30, 2015, 05:42:03 PM »
Ordered some more double sided tape so I can put my window visors back on.
AZcaveman
Reply #8328 on:
May 31, 2015, 02:18:49 PM »
Finally!! After worrying it maybe a wheel bearing going...i decided to let it go for a while longer to see if i could do a better job pinpointing the noise.
Wife drove car friday, she wont back it into garage like me. So when i went to move it into garage i was kind of hanging head out window to see, and bam, the noise was coming from REAR WHEEL! DOH! so later i drove more and confirmed, rear brake.
So just changed rear pads and rotors, and voila, no more noise! One of those pads had hit wear indicator. Yay!!!
Reply #8329 on:
June 04, 2015, 09:31:15 AM »
Dropped off my car this past Sunsay at the bodyshop. New color, fixing all dents, installing new suspension, mufflers, brakes and other maintenance stuff all at once.
Reply #8330 on:
June 04, 2015, 09:44:17 AM »
Omg I can't wait to see it! It's your turn now.!
Putting the summer wheels on after work!
Reply #8331 on:
June 04, 2015, 10:45:51 PM »
Spent some time removing the old cap assembly on my water tank and cleaning the tank out. The new cap is a bit tight, so I have to file the opening so the flange will fit properly. It should be back together by tomorrow.
Reply #8332 on:
June 14, 2015, 08:28:20 PM »
Today I drove an hour and change to pick up an OEM dual exhaust....and I put it in my car. Not the best idea, but too late now it's done. Lol.
Reply #8333 on:
June 20, 2015, 09:52:38 PM »
Threw a pair of 5mm spacers on the rear hubs. Now it sits nicely.
Reply #8334 on:
June 20, 2015, 10:47:24 PM »
Pulled the blower and intake manifold again. The sheet metal cracked at the flange again, so I brought my plenum to a different fabricator to have a billet piece machines and welded on. I also removed the water pump from the front to move it out back closer to the tank.
Some more changes are coming soon.
Reply #8335 on:
June 21, 2015, 03:14:00 PM »
Replaced both my axle. Axle vibration disappeared. Looks like my axles were not OEM to start with.
Thank you Tim for suggesting the tool to pop the ball joints, and thank you Thien for helping me out and being on speed dial when I had issue with stuff.
here is the axle comparison. I am not sure if my old axle were oem or not since it didn't have the rubber dampener, but 90% of the vibration is now gone.
driver side
passenger side
Last Edit: June 21, 2015, 03:43:58 PM by thisaznboi88
Reply #8336 on:
June 21, 2015, 08:01:47 PM »
Removed my rear bumper brace and broke off 3 of the 4 studs in the process. Found a place to mount my water pump and made some new water lines for it.
Reply #8337 on:
June 22, 2015, 03:47:40 PM »
Dropped it off at b 603 to get the driver's side window fixed, and a spot on the trunk touched up. Yup it was my fault.
I'll have to go back and have the trunk repainted if I want it perfect
Reply #8338 on:
June 25, 2015, 12:19:17 AM »
Had dual exhaust installed
Reply #8339 on:
June 26, 2015, 11:02:09 AM »
bought new lower ball joints and lower control arms. Car was making a thud noise when I turn and it was annoying the hell out of me.
555
556
557
558
