November 06, 2026, 10:15:29 PM
531
532
533
534
Topic: What did you do to your Gen7 today? (Read 3817564 times)
Reply #7965 on:
October 21, 2014, 09:09:28 PM »
Also not a bad idea to change out the sensor. The wiring to them do go bad over time.
Reply #7966 on:
October 22, 2014, 09:36:18 AM »
Changed my pcv.
Reply #7967 on:
October 22, 2014, 01:23:20 PM »
car Acceleration positioning sensor just took a dump. zero throttle response from the car.
Reply #7968 on:
October 22, 2014, 06:57:47 PM »
Well that sucks, so the CEL was legit then.... must be coincidence or bad luck that it happened right after you got fp working.
Purchased some all weather floor mats
Reply #7969 on:
October 22, 2014, 07:31:33 PM »
^ yeah I tried flashing the ecu back to stock and the CEL will not go away. It is permanent until the issue is resolved.
Rich I also send you a pm on v6p with Dom info.
Reply #7970 on:
October 22, 2014, 10:03:45 PM »
Got it, thx
Reply #7971 on:
October 23, 2014, 12:42:03 PM »
Fixed my issue. It wasn't the APPS it was a loose wire on the hondata harness. Too much vtec indeed
Reply #7972 on:
October 23, 2014, 01:12:44 PM »
Sucks you had to overnight the sensor and it wasn't even the problem.
Reply #7973 on:
October 23, 2014, 03:06:15 PM »
Yeah it was 100 bucks... but w/e looks like a common problem with people older accords.
Reply #7974 on:
October 25, 2014, 03:00:00 PM »
New floor mats, uploaded a new cal and did a datalog
Reply #7975 on:
October 25, 2014, 03:08:45 PM »
^ nice is Dom taking care of you? I am also having him do a few maps for me while I have Vits work up one for me also
10hp per sticker right?
Last Edit: October 25, 2014, 07:52:16 PM by thisaznboi88
AZcaveman
Reply #7976 on:
October 25, 2014, 11:20:27 PM »
Replaced wire going from adapter to ipod, got rid of annoying screech/hiss... Yeah-uh!
Reply #7977 on:
October 26, 2014, 02:14:30 PM »
Quote from: thisaznboi88 on October 25, 2014, 03:08:45 PM
Yes he is and yes to the stickers. I heard stickers about tuners actually bump you up to 15whp each
Dom actually turns around cals. quicker than I anticipated based on what I've heard about others. He had my 2nd ready to try in about 4hrs. I'm sure his schedule has a lot to do with it, so I may have gotten lucky.
I did have a fluke today where the Flashpro wouldn't see my ECU again. I'm gonna have to check those pins again, hoping they didn't start backing out with the frequent connecting that i've been doing. I left it connected for now
Reply #7978 on:
October 26, 2014, 03:24:29 PM »
I replaced my DTC unit and Tim hooked me up with some new pins. From the extra wiring he had laying around.
I am on my 4th map with Dom. Vtec is so much noticeable. With Vits we haven't tuned for vtec just yet. still doing 2-5k pulls. It still need fine adjustment to the AFR
Reply #7979 on:
October 26, 2014, 06:43:14 PM »
Yeah, I was suppose to pick one up from a junk yard and either inline splice the wires or do a twist lock AMP connection but never pursued it because it was working. Yeah, I got back my 3rd cal this evening. Once we're done, it's time to get some base numbers on a dyno then we have to start over again
531
532
533
534
