November 06, 2026, 09:30:46 PM
302
303
304
305
Topic: What did you do to your Gen7 today? (Read 3817452 times)
Reply #4530 on:
March 09, 2012, 02:18:51 AM »
swapped out my rear view camera good as new again
Reply #4531 on:
March 09, 2012, 09:04:52 PM »
Completed my new to me wheel refinishing project. Tomorrow is when the rubber meets the road. Literally.
Reply #4532 on:
March 09, 2012, 09:36:41 PM »
replaced my runner gasket, swapped in port and polished runners v2, replaced the gasket between the runners and IM, found out my p2r gasket was melted/warped to hell, swap in a TL-S magesium intake manifold, p2r spacer so I don't have to tap a hole for water meth, and added some new grounding wires.
Also worked on David headlights some more.
teaser version 2.1 and hopefully the best one. Just don't let a deer total this set.
its missing a picture of the other headlight.
Last Edit: March 09, 2012, 10:07:26 PM by thisaznboi88
Reply #4533 on:
March 10, 2012, 01:57:20 AM »
Found the Rattle !!! The sway bar bushing wasn't installed correctly is slipped off fixed it up and tight nice and quite again
Reply #4534 on:
March 10, 2012, 12:54:51 PM »
P2R Gaskets make me sad
This is my luck with the gasket... I know a few of you are running this gasket. So maybe you should check yours out also. The TB gasket had no issue tho since it doesn't get as hot as the runner/IM space.
Gold stuff is RTV copper gasket spray. AS you can see the holes are not circular anymore. It when from this.
TO
this is how ****ed up mine was within a month
My guess is that it got a little too hot for it. I tq it down to 16ft/lbs using the torque sequence.
Reply #4535 on:
March 10, 2012, 07:19:22 PM »
Is that what they recommend you tq it down to?
Reply #4536 on:
March 10, 2012, 07:23:17 PM »
16ft/lbs
I ask Thien also. I did it in 3 different steps for the tq sequence
Here is the new IM pix.
Reply #4537 on:
March 10, 2012, 09:58:54 PM »
Quote from: thisaznboi88 on March 10, 2012, 07:23:17 PM
16ft/lbs
How much better does it feel compare to the stock one ?
Did my front speakers swapped out stocked with some rockford fosgate p15652 also did my passenger side lock actuator
Reply #4538 on:
March 10, 2012, 10:37:51 PM »
Put some new rubber on my wheels and ordered a new suspension. The curtain isn't getting pulled yet.
Reply #4539 on:
March 11, 2012, 01:10:39 AM »
@ CNA feels pretty damn good. lol it flows 13% better then the OEM accord one and I have runners. So it really takes advantage breathing easier. There is not for me really to port and polish since its pretty smooth already.
Now I wish I had TL-s cams. lol
Reply #4540 on:
March 11, 2012, 01:39:32 AM »
TL-S cams and a bump in compression would be nice. You'd want to be able to tune it though. Another thing is at that point, you would have to get an AFR gauge so you can monitor if you're running too rich or lean.
Reply #4541 on:
March 11, 2012, 02:41:12 PM »
@ Tim yup your right. I might hitting up for a few more stuff on my car. lol
Reply #4542 on:
March 11, 2012, 08:09:11 PM »
Anyone talk to Misha about his TL-S cams?
Reply #4543 on:
March 11, 2012, 10:04:06 PM »
I washed the accord and the jeep. Accord is going in for paint tomorrow. After this the entire car will have been repainted apart from the roof. I'm getting the entire right side, rear end, and from the a pillar to the quarter panel on the left side painted. Getting the headlights professionally restored too.
Last Edit: March 11, 2012, 10:05:41 PM by wtcii
Reply #4544 on:
March 12, 2012, 05:01:28 PM »
Mine got a very good cleaning, and summer wheels are on....
302
303
304
305
