June 21, 2026, 10:01:28 AM
251
252
253
254
Topic: What did you do to your Gen7 today? (Read 3585328 times)
0 Members and 37 Guests are viewing this topic.
Reply #3765 on:
July 15, 2011, 03:56:06 PM »
Actually took my ride to a car wash today! Since I been uptown more I don't have the privelage of washing it myself in my driveway anymore
Reply #3766 on:
July 17, 2011, 05:30:02 PM »
I had to drive home last night with only my fogs. Found out that my fuse holder had gotten wet and corroded the contacts. I cleaned that up and verified that the fuse was ok. Its all set now. I also restored my headlight lenses with the mother's kit. I had to sand the hell out of them. Overall, they look 90% better. Time to redo those retros....
Reply #3767 on:
July 17, 2011, 10:54:12 PM »
@Rich: consider getting the new relay from TRS. They are in water proof units now.
Did nothing to my car today. Put in 91 OCT gas and the car seems a lot happier. Mostly did work on my dad MDX. Cleaned out the IM, which look like crap. Too much crap from ERG and PCV? Clean it down to bare metal again using TB/ CARB cleaner. Then popped off the valve cover and was amazed how much the synthetic oil had cleaned up the valve train.
Reply #3768 on:
July 17, 2011, 11:12:17 PM »
tore into my dash swapped out rear speakers and clean my spare tire area one less rattle fix
Reply #3769 on:
July 18, 2011, 12:48:44 AM »
Worked on my engine wire harness. I started by routing the wires for the crank sensor, vtec solenoid, vtec pressure sensor, oil pressure sensor, crank position sensors a and b, map sensor, tps, iacv, and the trigger and power wires for the coil packs. I extended what wasn't long enough and shortened what was too long. I still have to run the sensor wires for a few other sensors, then I'm going to work on running the sensor power and ground wires.
Reply #3770 on:
July 18, 2011, 06:36:16 AM »
Quote from: thisaznboi88 on July 17, 2011, 10:54:12 PM
Thats good to know. I'll look into that when I get my new shruds from them. I probably shouldn't have gone overboard with the water while washing my engine bay. Thats how the fuse got wet in the first place lol.
Last Edit: July 18, 2011, 06:41:00 AM by Rich01
Reply #3771 on:
July 18, 2011, 09:00:52 AM »
Quote from: Rich01 on July 17, 2011, 05:30:02 PM
Sylvinya came out with an amazing headlight restoration kit.
Reply #3772 on:
July 18, 2011, 09:53:50 PM »
did valve adjustment.. exhuast were soo tight even the smallest/thinnest feeler could not get in. long over due.
Reply #3773 on:
July 20, 2011, 04:45:41 PM »
Upgraded the firmware of my parrot bluetooth kit and finally ordered a front lip. Gotta hide all the scrapes my brother left on the front bumper.
Reply #3774 on:
July 20, 2011, 08:22:26 PM »
We actually sell this stuff a guy locally made and it's pretty amazing stuff
http://www.youtube.com/watch?v=MlpLZlFTsjk
It's that quick and easy it's a lil pricey tho and a can only does six sets of headlights it's good stuff though
Also replaced my driver door switch :p
Reply #3775 on:
July 20, 2011, 08:37:38 PM »
Funny. I could do that with a can of clear from the auto parts store for about $5. True story.
Reply #3776 on:
July 20, 2011, 08:39:00 PM »
If I'm seeing the steps right its...
Glass cleaner
Wet sand
spray clear?
Reply #3777 on:
July 20, 2011, 10:08:20 PM »
Pretty much.
Reply #3778 on:
July 21, 2011, 12:26:27 AM »
Ya that would probably do the same thing now that u mention it :p aha well the process works well at least
Reply #3779 on:
July 21, 2011, 01:51:38 AM »
Did more work on my engine harness. I didn't make a lot of progress though. It's still too hot to work out in the garage.
251
252
253
254
