June 21, 2026, 10:01:26 AM
Pages: « First < Previous 1 ... 249 250 [251] 252 253 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3585328 times)
0 Members and 37 Guests are viewing this topic.
« Reply #3750 on: July 04, 2011, 04:56:02 PM »
And I know why.
« Reply #3751 on: July 04, 2011, 08:09:44 PM »
And I know why.
My hero!
« Reply #3752 on: July 04, 2011, 08:53:11 PM »
I'd better be.
« Reply #3753 on: July 05, 2011, 06:01:41 PM »
Ordered Exhaust hanger mount for J-pipe section. notice the rubber in the mount was broken while I was putting on the Borla exhaust. Hope this helps the rattling at certain rpm
« Reply #3754 on: July 06, 2011, 11:24:08 PM »
Took my car over to the Nissan dealership where I bought my car for a free oil change (GT synthetic blend?), then drove next door to the Honda dealership and bought a case of Honda ATF-DW1. Took it home, drained and filled it, drove it, drained and filled it, drove it, then finally drained and filled it a last time. I also rotated my tires. For some reason my car no longer pulls to the left anymore, and the steering wheel is straight again. Weird.
Reputation Power: 18
alpha pfffft.
« Reply #3755 on: July 07, 2011, 01:50:05 AM »
Jeff, did you rotate your tires front to rear?
« Reply #3756 on: July 07, 2011, 02:06:07 AM »
Yeah, I have directional tires, so that's the only way to do it.
alpha pfffft.
« Reply #3757 on: July 07, 2011, 02:33:18 AM »
This article may help you out a bit.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=12
« Reply #3758 on: July 07, 2011, 07:10:59 AM »
I started her up. It's been over a week since I did that.
« Reply #3759 on: July 07, 2011, 11:49:18 AM »
order some new window washer nozzles my where clogged up
« Reply #3760 on: July 09, 2011, 12:39:41 PM »
Installed my exhaust hanger mount this morning. Still hear a little rattle. It could be coming from the flex section of the stock j-pipe that is trashed right now. It looks like the old hanger mount was fabricated to fit. It is slightly smaller than the replacement and had the indentation of the bolt head that it covers inside of it. Anyway, replacement made the sounds 90% better.
« Reply #3761 on: July 09, 2011, 02:46:45 PM »
Moved it out of the way of some Mexicans that were cutting the neighbor's yard. Absolutely no fucking regard for a person's property.
« Reply #3762 on: July 09, 2011, 03:37:28 PM »
Replaced some fittings on my aftercooler set up.  Ran into a snag on the clearance with the fittings on the heat exchanger.  Time to return some stuff and formulate a new plan on how I'm going to run my lines.  I changed the oil and replaced the rotors and pads on the Fit today too.  Maybe I'll go out and do some more work on my car later tonight.
« Reply #3763 on: July 15, 2011, 09:15:35 AM »
Cinched up a couple hangers on my exhaust yesterday since it moved around entirely too much and bumped into my bumper a lot. Now that shit is nice and tight.
« Reply #3764 on: July 15, 2011, 01:05:50 PM »
took out my fog retros and put in regular fogs..  Embarrassed
Pages: « First < Previous 1 ... 249 250 [251] 252 253 ... 596 Next > Last »   Go Up
