August 21, 2026, 12:04:09 PM
Pages: « First < Previous 1 ... 80 81 [82] 83 84 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3673353 times)
« Reply #1215 on: July 29, 2009, 12:06:35 PM »
^^ is your trotle body drive by wire? if so, check connector on TB, unplug is and plug it bad in, then reset computer and see if it works
ROLO pfffft.
« Reply #1216 on: July 29, 2009, 12:13:38 PM »
^^ I reset the computer and at first it was fine (for a few minutes).. then it happened again.. and it's mos def the TPS Sensor
« Reply #1217 on: July 29, 2009, 12:56:29 PM »
I would change the O2 sensor first and see if the problem goes away. I know at least in Toyota's those sensors can cause all sorts of codes.
« Reply #1218 on: July 29, 2009, 01:10:34 PM »
I would also replace the O2 sensor first.  Honda doesn't sell the TPS alone.  They only sell it as part or the entire TB assembly.  You would have to purchase an aftermarket one instead.  I may have an extra one if you want it Rolo.
NWINNIE34 pfffft.
« Reply #1219 on: July 29, 2009, 01:54:02 PM »
bought her a new oil fill cap..... nice n shiny !
ROLO pfffft.
« Reply #1220 on: July 29, 2009, 02:28:15 PM »
Sure Tim how much?
Paulius005 pfffft.
« Reply #1221 on: July 29, 2009, 09:29:33 PM »
Installed KnuConceptz battery terminals and completed my Big 3 upgrade. pics to come
Paulius San Jose, CA
lilmalu
lilmalu pfffft.
« Reply #1222 on: July 29, 2009, 10:25:11 PM »
changed my oil, transmission fluid, and spark plugs. What else should be done for a 100K service?
Reputation Power: 25
« Reply #1223 on: July 29, 2009, 10:26:20 PM »
You could check filters, engine air, cabin, etc.
« Reply #1224 on: July 29, 2009, 10:42:14 PM »
Quote from: "ROLO"
Sure Tim how much?
Replace the O2 sensor first and see if you get the TB code still.  I'll dig around my parts to see if I can find it.  If not, I'll try and find out who makes a replacement.
k24low20z pfffft.
« Reply #1225 on: July 29, 2009, 10:54:08 PM »
i cut my shifter and installed the razo shift knob i got from scott..looks so nice now..
lilmalu
lilmalu pfffft.
« Reply #1226 on: July 29, 2009, 10:54:08 PM »
i cleaned the intake filter a month ago, and i should check the cabin filter since i changed that last year
« Reply #1227 on: July 29, 2009, 11:58:08 PM »
I changed my cabin filter n order a new break switch to fix the random tcs light .
Blackhawk pfffft.
« Reply #1228 on: July 30, 2009, 12:58:55 AM »
Made my auto down/up window switch "re-learn" itself.
ROLO pfffft.
« Reply #1229 on: July 30, 2009, 08:36:18 AM »
k24low20z and I replaced my TPS sensor and the car is running smooth.
Pages: « First < Previous 1 ... 80 81 [82] 83 84 ... 596 Next > Last »   Go Up
