April 28, 2026, 06:46:03 PM
Author Topic: How To: Center Pocket  (Read 5647 times)
« on: February 12, 2010, 11:28:33 PM »
This will be a DIY on removing and installing the center pocket. Sorry for the crappy pics. I was using my cell phone, but I hope this will help anyone who will be doing this. I will try to be as thorough.
Tools:
Philips Screwdriver
Flathead Screwdriver
1: Open the "This Is Not An Ashtray" pocket and Power Outlet pocket.
2: Pull up on the shifter assembly trim.
3: Disconnect heated seat plugs by pushing in the little tab in the middle of the plug. (If applicable)
For Automatics. (Skip this step if you have a manual transmission)
4: Use a small flathead screwdriver to pry open the shifter assembly emergency gear selector. Use your key and press down to move your shift knob to a position to where you can remove your shifter assembly trim.
5: Remove the "This Is Not An Ashtray" rubber cover.
6: Unscrew the two bolts located on the outer edges of the two lower pockets.
7: Use a flathead screwdriver and pry open the "This Is Not An Ashtray" tray.
8: Under the tray you will see 2 screws. Proceed to unscrew them.
9: Pull up on the lower pockets.
10: Unplug the power outlet plug.
11: Unscrew the 2 screws that hold the center pocket down.
12: Pull the center pocket out.
Install center pocket in and install in reverse order. Here I replaced my center pocket for the carbon fiber one. The outcome is as follows.
« Reply #1 on: February 13, 2010, 12:24:38 AM »
I never knew about the emergency gear selector.... I always just put the key in. Thanks for dropping knowledge on me
