August 06, 2026, 01:45:39 PM
Progress Sway Bar
Topic: Progress Sway Bar (Read 20619 times)
SnOoZeR
Progress Sway Bar
February 09, 2010, 02:09:09 PM »
i was looking towards upgrading my tl-s rear sway bar to a progress rear sway bar.
i noticed that the progress TL sway bar is 24mm and our accord sway bar is 22mm.
i was wondering if the progress TL rear sway bar would fit onto my 7gen since the TL-S rear fits?
did anyone ever try this?
Re: progress sway bar
February 09, 2010, 04:03:35 PM »
You probably won't notice a huge difference. I believe the Accord rear sway bar is like 14mm, while the TL-S rear sway bar is 20mm. I have a Comptech rear sway bar which is 22mm. I'm not sure if you will notice much of a difference between the 20mm and 24mm. I'm pretty sure the TL rear sway should fit though.
neoryan7
March 05, 2010, 03:38:46 AM »
I think the tl rear sway would fit and when I went from the 20 to 22mm I noticed a difference.
March 05, 2010, 11:41:04 PM »
Quote from: "neoryan7"
you must be really in-tune with your car...2 mm is really realllllly small
March 06, 2010, 09:06:30 AM »
it just might make a difference. here's what i'm thinking. with the tl-s sway 27 & 20mm bars (front and back) our cars tend to under steer. so a 24mm rear might just give him the perfect balance. but it depends on what you like. under steer or over steer?
daslowun
Progress Sway Bar
February 20, 2012, 12:09:05 PM »
Hey all, I have a question about the 22mm progess sway bar. Does anyone know if it will clear the oem dual exhaust on my v6? It said it fit both 4cyl and v6 models but I wanna know if I will have any hitting issues? Thanks any help would be greatly appreciated!
Re: Progress Sway Bar
February 20, 2012, 03:02:24 PM »
I'd guess and say that it will since they claim it will. Don't trust Progress?
daslowun
Re: Re: Progress Sway Bar
February 20, 2012, 03:20:02 PM »
No its not that, just seen other people saying that there sway bars touch there exhaust but thats maybe because they have aftermarket ones? Lol but I just got an email its on backorder. Smh
February 20, 2012, 07:12:08 PM »
People have had the oem TLS RSB hit. Bend a hanger and call it a day.
daslowun
February 20, 2012, 07:21:11 PM »
Hmm quick fix! lol but hey if it works ..
February 20, 2012, 08:02:03 PM »
You're probably better off with the TL-S rear sway anyway. I'd strongly recommend that you upgrade your front sway bar while you're at it. By stiffening up the rear end only, you will be more prone to oversteer. I had only the rear sway bar upgraded with a Comptech 22mn bar at one point and speak from experience. There were a few times that the back end kicked out because of it.
daslowun
February 20, 2012, 08:55:44 PM »
Yeah if I get the set it wouldve been front and back but thnx bro! Good to know! Now 2nd question, if I do go with the tl-s SB would I need to replace the front also? And secondly where can I find one because I dnt think ima b getting the progress anymore... Its on backorder.
February 20, 2012, 09:55:10 PM »
Quote from: daslowun on February 20, 2012, 08:55:44 PM
This.
Quote from: timot_one on February 20, 2012, 08:02:03 PM
When I ordered my sway bar (base TL bar) I called up the local Acura dealer. They told me $90 for just the rear. I respectfully declined and just ordered it off line. I bought mine from 1hondaparts and the grand total for the bar, brackets, bushings, and bolts was under $50. The TL-S bar was like a dollar more or something like that. If I remember correctly, the front bar is double that for just the bar.
daslowun
February 20, 2012, 10:14:07 PM »
Damn thanx bro, I just asked about the front to double check and since its oem I didnt know..
February 20, 2012, 10:24:24 PM »
If you're going to order online, I'd recommend calling AutoFair Honda and ask for Ryan or Rich. I'd recommend replacing both front and rear. Again, the whole idea behind upgrading your sway bars is less body roll. If you upgrade only the front or only the rear, you're going to disturb the balance of your car and it will affect the handling negatively. Then it becomes a safety issue because you will have too much oversteer or understeer. The rear sway bar is a lot easier to replace than the front, but well worth the upgrade.
By the way. There was already another thread on the Progress rear sway bar (with the exact same title as yours). I merged the two threads together. It would have been better for you to post in that thread instead of creating a new one. Please search first before posting new topics.
Last Edit: February 20, 2012, 10:30:47 PM by timot_one
