August 06, 2026, 02:48:51 PM
Author Topic: Progress Sway Bar  (Read 20627 times)
B.R.03EX pfffft.
« Reply #15 on: February 20, 2012, 10:28:03 PM »
^Yeah that. I ordered mine before I knew about AutoFair Honda.
I would definitely recommend going with the TL-S bar though. The base TL bar is a nice upgrade but after a few weeks I wanted more.
« Reply #16 on: February 20, 2012, 10:35:14 PM »
It's also important to mention that the TL-S sway bars are solid, while the base TL are not.
« Reply #17 on: February 20, 2012, 11:20:49 PM »
Aren't the stock front sway bar on our accords and the base tl front sway bar the same one?
daslowun
daslowun pfffft.
« Reply #18 on: February 21, 2012, 07:13:41 AM »
Thanx all for the help, sorry next time I will search before posting...i just posted quick from my job I.didnt even get a chance to go thru nuthn else.
« Reply #19 on: February 21, 2012, 08:50:21 PM »
I don't believe they are the same.
« Reply #20 on: February 21, 2012, 10:18:34 PM »
Same thickness, no? Ones solid, ones hollow?
« Reply #21 on: February 22, 2012, 09:37:04 AM »
Honestly, I really don't know the differences.  I'm not going to make stuff up either.  I'm sure someone has done the research, but I'm not about to go searching for the results.  If you're going to upgrade your front sway bar, you're better off with the TL-S one anyway.  Wink
HEcreated487 pfffft.
« Reply #22 on: February 22, 2012, 11:32:57 AM »
Tim- Did you upgrade the end links for the front TL-S sway?  I read that there is some "play" in re-using the Accord end links and the TL-S links require drilling. Any info would be great Smiley
« Reply #23 on: February 22, 2012, 11:54:48 AM »
Meh.  Swapping sway bars, both front and rear) was the first upgrade I did to my car way back when.  I never changed out the front end links.  Since the bar was the same shape.  It's been holding up fine for the last 5 years.
« Reply #24 on: February 22, 2012, 12:50:32 PM »
for the TL-s front yeah you would need TL-S end links since they are beefier so drilling is necessary to make them fit
Pages: « First 1 [2]   Go Up
