September 29, 2026, 06:32:41 PM
Fuel Smell in cabin with heat/AC on
Topic: Fuel Smell in cabin with heat/AC on (Read 9327 times)
February 03, 2010, 11:07:53 AM »
Well a month or two ago I had an issue where my gas tank was over filled. There was an issue with the Gas pump, and it did not shut off. I did not notice until fuel was spilling out onto the ground. I had a CEL for a week or two, and it went away and I thought all was fine. Last week I started to smell fuel when I was stopped at lights, and my car was allowed to idle. I have contacted Paul, and we have determined that the charcoal canister is probably fouled. I have ordered the canister and will have it replaced to see if this clears up the issue. I'm posting this with the assumption that at some point someone will encounter a similar issue. I will update when the new canister is installed, and see if that cures the problem.
Re: Fuel Smell in cabin with heat/AC on
February 03, 2010, 07:00:03 PM »
That'd be good to know as the same thing happened to me the other night. I may not notice it until much further down the road though.
February 03, 2010, 07:44:04 PM »
how does an overflow of gas cause this...wouldn't it just pour out the fill area?
February 03, 2010, 08:00:25 PM »
No there is a line that comes off the filler neck, and into the canister it is there to absorb excess vapor. When liquid fuel gets into the canister it fouls the active charcoal. This is a brief description but, you can get the idea.
February 03, 2010, 08:06:00 PM »
That part, I didn't know about. I really hope that didn't happen to mine. How much that shit cost you Mike?
February 03, 2010, 08:09:28 PM »
HE sent me the info, it was like $100
February 03, 2010, 08:12:13 PM »
That's not too bad. I just don't want to be surprised by some exorbitant fucking price if it did get fouled.
February 03, 2010, 08:13:31 PM »
It was $94 with tax and shipping the dealer wants $48 to install it so I'll let them to the work. Saves me the trouble.
February 03, 2010, 08:55:50 PM »
That's still not bad. Good to know.
January 25, 2011, 11:14:33 AM »
This smell went away for awhile after having the fuel pressure regulator changed but, is back after the last couple really cold days... I thought I had it licked!
January 25, 2011, 01:38:00 PM »
So much for you thinking Mike. Let that be a lesson to you.
GNskates
April 25, 2011, 08:34:20 PM »
where is the fuel pressure regulator at? idk if its the one right next to the fuel rail on the left or if its somewhere else. i had a friend look up TSBs for it and he found it in near the gas tank. i need to replace it because before the car wouldnt start in the morning somtimes and long 0cranks, sometimes my gas would be trippy.. help would be appreciated.
April 25, 2011, 11:27:36 PM »
The fuel pressure regulator is on the in tank fuel pump.
