November 04, 2026, 06:58:17 PM
Pages: « First < Previous 1 2 3 [4]   Go Down
Author Topic: Rate your brakes! (aftermarket products discussion)  (Read 98881 times)
spiceisler
spiceisler pfffft.
« Reply #45 on: December 04, 2014, 05:54:54 PM »
planning on swapping out the Fastbrakes Wilwood 12.6" front BBK for some AP Racing 4pot 13" with floating rotors. anyone with experience with this?
Why are you changing from the Wilwoods?
« Reply #46 on: December 04, 2014, 08:44:11 PM »
^ lol bump from 1 year ago.
Pascal
Pascal pfffft.
« Reply #47 on: December 04, 2014, 08:47:52 PM »
almost 2 year bump ! we are close to 2015 now Wink
pbplayer257
pbplayer257 pfffft.
« Reply #48 on: April 09, 2016, 08:31:46 PM »
So does anyone have anything good to report on any aftermarket brake setup? Browsing through this thread, no one seems to be happy with anything on the market.. Been doing a lot of research for new rotors and pads and it seems like everything out there, including stock setup warps very easily. Are any rotors made out of quality materials or is every rotor made out of cheap chinese materials...
« Reply #49 on: April 09, 2016, 11:02:09 PM »
I've had good results with RL calipers, Rotora discs and EBC Yellowstuff pads.  It's just about doing your research to see which companies don't use Chinese steel for the rotors.
« Reply #50 on: April 10, 2016, 07:44:38 AM »
I've had mixed results with EBC red and yellow stuff pads mixed in with EBC slotted rotors on my setup.  I ended up going back to stock but leaving in the stainless steel brake lines.
pbplayer257
pbplayer257 pfffft.
« Reply #51 on: April 10, 2016, 11:10:35 AM »
Why didnt you like the ebc setup? Ive been looking into ebc rotors and green stuff pads, looks like they're made in the us/uk.
« Reply #52 on: April 11, 2016, 08:34:45 AM »
I have the RL calipers and I installed the EBC slotted rotors and green stuff pads almost two years ago.  I just started getting a lot of bad vibrations when braking, causing me to believe they are warped already.  This will be the third set of warped rotors I've had since I installed the RL calipers.  I'm just buying cheap aftermarket rotors from now on since even the expensive ones don't seem to last more than 2-3 years.
« Reply #53 on: April 11, 2016, 10:01:03 PM »
I just recently did an upgrade to cr-v calipers with tsx rotors. Basically just oem replacement from advance auto for the pads and rotors. Too soon to tell as far as longevity but based on past experience with the stock accord brakes, I'm already past the point on the new setup where the stock setup would start to give vibrations.
« Last Edit: April 12, 2016, 11:37:28 PM by CrackerTeg » Logged
« Reply #54 on: April 12, 2016, 10:28:09 PM »
I didn't like the EBC setup because I didn't feel like I got pedal response from them and I was getting weird vibrations all the time but the rotors weren't warped.
Pages: « First < Previous 1 2 3 [4]   Go Up
