August 13, 2026, 11:39:40 AM
Hybrid Mirror Wiring Guide
Topic: Hybrid Mirror Wiring Guide (Read 61474 times)
February 14, 2009, 10:29:45 PM »
Drivers Side
LED Wires
purple = ground to metal on door
pink = 12 volts to red/blue - found at top of fuse box (large white plug)
Mirror Wires
yellow/black (mirror) to green/white (door harness)
yellow/red (mirror) to blue/black (door harness)
yellow/white (mirror) to blue/white (door harness)
Passengers Side
LED Wires
pink = 12 volts to brown - found at top of fuse box (large white plug)
Mirror Wires
blue/black (mirror) to green/white (door harness)
blue/green (mirror) to red/yellow (door harness)
yellow/white (mirror) to white/red (door harness)
Pics will be up later when it's warm out.
Re: Hybrid Mirror Wiring Guide
February 19, 2009, 04:49:03 PM »
I hope this helps Milan when he helps me install my TSX mirrors...
February 20, 2009, 12:17:25 AM »
I don't think it will help out with anything more than the install of the ground wires for the turn signals. Fortunately, I can check the wiring of my TSX mirrors for you. I will have that info here when I have a chance to look at 'em. I should have that for you by Saturday.
February 20, 2009, 12:00:25 PM »
Thanks Tim.
kaabob
January 17, 2010, 09:34:02 PM »
The 06' Hybrid mirrors are heated. Are there wires that come separately for the heating element?
January 17, 2010, 11:01:39 PM »
Quote from: "kaabob"
yes.. 2 more black and grey wires.. i have the 06-07 tsx with the heating element but i never got around to wire it up for the heater to work and living in FL i dont really need it..i remember tim had said that it can maybe be hooked up to the rear window defroster switch or just add a aftermarket switch..
January 18, 2010, 08:09:13 AM »
I've never worked with the heated mirrors, and I don't have the wiring diagram for them, but it should be really easy to hook up the heating element.
mnkyman
January 18, 2010, 03:04:37 PM »
if you really want, you can buy the hybrid accord mirror switch (it looks the same as ours, but to the left of the knob for adjusting mirrors there is a small button for the heat option)...when I looked into it a while back it was like $50 for that button, so I would just do what everyone else suggested above and wire it into something like your defroster...or maybe even a standard switch on the dash where the fog switch is
Sam
-|- 2006 I4 Sedan SE
January 18, 2010, 03:55:24 PM »
I'm not sure if the hybrid mirror heated switch is a constant on/off, or just a timed latched switch (stays on for 10 minutes and then shuts off). That might be the only problem you will encounter. That's why I suggest using the rear defrost as a trigger. At least we know that is a latched switch.
January 19, 2010, 09:11:00 PM »
My Accord has the mirror heater switches right next to the power mirror knob...is this not what you guys are talking about? so I want hybrid mirrors, are they heated as a standard option for the hybrids? if so, then the hybrid mirrors should be plug and play for my car right?
January 19, 2010, 09:24:52 PM »
I'm not sure about them being plug and play. Only one way to find out. If they aren't plug and play, at least you know that you can just wire them up yourself with a little help from people on here.
mnkyman
January 19, 2010, 09:44:32 PM »
Quote from: "sherker55"
really? picture?
Sam
January 19, 2010, 10:10:43 PM »
I'll try to take some pics tomorrow if you don't believe me!
JK...yeah, I have the 07 Sedan V6, 6 MT...carbon fiber interior, leather heated seats, everything black on inside...everything but Navi, foglights, and trunk spoiler...
January 20, 2010, 06:43:48 PM »
Quote from: "mnkyman"
really? picture?
ok, I have the pic on my memory card. how do I put it on here? does it have to come from a URL?
January 20, 2010, 08:15:52 PM »
Quote from: mnkyman
Quote from: sherker55
really? picture?
here you go non-believers!
Last Edit: April 13, 2011, 04:43:29 PM by sherker55
