November 08, 2026, 01:36:37 PM
Author Topic: General Information Regarding the CM's  (Read 25252 times)
Reputation Power: 25
« on: December 07, 2009, 04:52:15 PM »
I think this link was on the old gen7, but I had this link bookmarked on an old computer. So, I thought I would share it. Credit goes to BenjiBoy650 on driveaccord. It has a lot of useful information. I know some of this is redundant but I thought it would be best to just leave it all together. Since it applies to both i4 and v6 models, I wasnt sure where to post this. Hope this can help someone.
http://www.driveaccord.net/forums/showthread.php?t=5095
This FAQ is not meant to answer most of your detailed questions in a nutshell. It is meant to give you a place to start looking for an answer. You still have to do your own reading and draw your own conclusions.
Of course, this FAQ is not meant to be used as a Bible or as a replacement for common sense. It is only meant to be used as a guide. Do not go out and pour 5.3 quarts of oil into your car and assume the oil is at the correct level. If you bring the part number for the brake pads into your Honda dealer and they tell you that you have the wrong part number, I would generally advise you to believe them.
Good luck and happy motoring
Table of Contents
Post 1 - This Post
Table of Contents only
Post 2 - General Information
1) Trim Levels
2) Engine/Codes
3) Transmissions
4) Fuel Information
5) Tire Information
6) Paint Codes
7) Acronyms
Post 3 - Model History
1) Detailed Trim Level and Features info
2) Drivetrain info
Post 4 - Maintenance Items (Part #'s)
1) Air Cleaner/Replacement Instructions
2) AT Filter
3) Battery
4) Brake Pads/Shoes
5) Cabin Air Filter/Replacement Instructions
6) Fluid Capacities
7) Light Bulbs
8) Oil Filter
9) Spark Plugs
10) Wipers
Post 5 - Problem Areas
1) Automatic Transmission Failure
2) Radio Problems
3) Radio/Head Unit Removal
4) A-Pillar/window rattles
5) Brake vibrations
6) Premature upholstery wear
7) Taillight-Quarter Panel peeling/damaged paint
8) Grinding/Groaning noise after cold start
9) Maintenance Required Light
10) Oil Consumption
11) First oil change
12) Fuel Consumption/Fuel Economy
13) Engine vibrations
14) Trunk Leak
15) Glass Replacement
16) Driver's Side Window Rattle
17) 6MT 3rd Gear Pops Out
Post 6 - Modifications
1) Acura TL rear sway bar
2) V6 6-speed/TL front strut tower brace
3) TSX mirrors w/ side turn signals
4) Wheels
5) Illuminated steering wheel controls
6) Inspire headlights/foglights
7) Foglights
8) HFP package (Honda Factory Performance)
9) Exhaust Tips
10) OEM Spoiler/Wing
11) Trunk Lid Garnish (Cover, Liner)
12) Auto-dimming mirror
13) Homelink/Home-Link
14) Playing TV/DVD on the NAV screen
15) Aux input
16) Customizing Navi boot screen
17) Detailing
18) Clear Bra
19) Speakers
20) Tires
21) Winter Tires
22) Oil
23) Oil Filter
24) Tire Pressures
25) Gas
26) TSX Intake Manifold
Post 7 - Parts
1) Part Source (OEM)
2) Part Sources (aftermarket)
Post 8 - Torque Specs
1) Lug Nuts
2) Oil Drain Plug
3) AT filler bolt
4) AT drain bolt
5) Spark plugs
General Information
1) Trim Levels
DX (sedan only)(2003-2004)
VP (sedan only) (2005+)
LX
LX-SE (2005 Coupe, 2006 Sedan)
SE (2007 Sedan)
LX V6
LX V6 SE (2005 Coupe)
SE V6 (2007 Sedan)
EX
EX-L (EX with Leather)
EX-L NAV (EX with Leather and Navigation System)
EX V6 (2003-2006)
EX-L V6 (2007+)
EX V6 NAV (EX V6 with Navigation System)
EX-L V6 Nav (2007+)
EX V6 6MT (EX V6 with 6-speed manual. For 2003-2005, available on Coupe only, 2006+ Coupe and Sedan)
EX-L V6 6MT (2007+)
EX V6 6MT NAV (EX V6 with 6-speed manual and Navigation System. For 2003-2005, available on Coupe only, 2006+ Coupe and Sedan)
EX-L V6 6MT (2007+)
Hybrid (2005+)
Hybrid NAV (2005+)
2) Engine/Codes
K24A4 – DX, LX, EX
2.4L Inline-4, DOHC i-VTEC, 16 valves
160HP @ 5500RPM
161LB-FT @ 4500RPM
J30A4 – LX, EX
3.0L V6, SOHC VTEC, 24 valves
240HP @ 6250RPM
212LB-FT @ 5000RPM
J30/IMA – Hybrid
3.0L V6, SOHC i-VTEC with VCM*
255HP @ 6000RPM
232LB-FT @ 5000RPM
2006+ K24A8*
166HP @ 5800RPM
160LB-FT @ 4000RPM
2006+ J30A5*
244HP @ 6244/6250RPM (2006/2007+)
211LB-FT @ 5000RPM
2006+ Hybrid*
253HP @ 6000RPM
232LB-FT @ 5000RPM
*SAE J1349 Revised 8/04
3) Transmission
2003-2005
Coupe – 5-speed manual (I4 only), 5-speed automatic, 6-speed manual (EX V6 only)
Sedan – 5-speed manual (I4 only), 5-speed automatic
2006+
Coupe – 5-speed manual (I4 only), 5-speed automatic, 6-speed manual (EX V6/EX-L V6 only)
Sedan – 5-speed manual (I4 only), 5-speed automatic, 6-speed manual (EX V6/EX-L V6 only)
4) Fuel information
Tank size – 17.1 gallons
Automatics
2003-2005 I4 24/33
2006 I4 24/34
2007+ I4 21/31
2003-2005 V6 21/30
2006 V6 20/29
2007+ V6 18/26
2003-2005 Hybrid 29/37
2006 Hybrid 25/34
2007+ Hybrid 24/32
Manuals
2003-2006 I4 26/34
2007+ I4 23/31
2003-2005 V6 20/30
2006 V6 21/30
2007+ V6 18/27
5) Tire information
Example: P205/65R15 91H
P - Passenger car tire
205 - width of the tire, in millimeters
65 - aspect ratio of the sidewall (ie. height sidewall is 65% the height of the tread width of 205mm)
R - Radial. Sometimes a letter will come before the R. This will indicate the speed rating in absense of the 91H
15 - height of the "hole in the tire" (for the rim), in inches
91 - load rating. Higher # = ability to support more weight
H - speed rating. Indicator of how fast a speed the tire can safely travel. Normally it will be well over 100MPH.
Tire Sizes
DX/VP – P195/65R15 89H
LX – P205/65R15 92H (2007+ Coupe use EX tire/wheel)
LX-SE – P205/60R16 91V
EX – P205/60R16 91V
2003-2005 LX V6 – P205/60R16 91V
2003-2005 EX V6 – P205/60R16 91V
2003-2005 EX V6 6MT – P215/50R17 93V
2006+ all V6 – P215/50R17 93V
All Hybrid - P215/60 R16 94V
Tire Models
Bridgestone Turanza EL41
Michelin Energy MXV4 S8
Michelin Pilot MXM4 - Mounted on 17" wheels only
6) Paint Codes
Alabaster Silver Metallic NH-700M
Carbon Bronze Pearl YR-562P
Deep Green Pearl G-516P
Desert Mist Metallic YR-538M
Eternal Blue Pearl B-96P
Graphite Pearl NH-658P
Nighthawk Black Pearl B-92P
Redondo Red Pearl R-522P
Royal Blue Pearl B-536P
San Marino Red R-94
Sapphire Blue Pearl B-517P
Satin Silver Metallic NH-623M
Taffeta White NH-578
7) Acronyms
ABS - Anti-lock Braking System
ACM - See VCM
ANC - See VCM
CAI - Cold Air Intake, aftermarket modification in hopes of finding more power
CEL - Check Engine Light
CHMSL - Center High Mounted Stop Lamp. The brake light mounted at the back/center of the car, normally on the rear shelf (behind the seat) or on the trunk.
DBW - Drive By Wire (electronic throttle control, no direct linkage on the gas pedal)
DIY - Do It Yourself
DOHC - Dual OverHead Camshaft
DRL - Daytime Running Light
EBD - Electronic Brake Distribution
EGR - Exhaust Gas Recirculation valve/port
EX-L - EX with Leather
EX-VL (uncommon) - EX V6 Leather (all EX V6 come standard with Leather)
GC - German Castrol
GLC - Grade Logic Control (helps transmission get the proper gear)
HAH - Honda Accord Hybrid (2005+ only)
i-VTEC - intelligent Variable valve Timing Electronically Controlled
IMA - Integrated Motor Assist, available on Hybrid only (gas+electric drivetrain)
M1 - Mobil 1
MAF - Mass Air Flow sensor (only on some models)
MIL - Malfunction Indicator Lamp (same as CEL)
NAVI - Honda Satellite Linked Navigation System
OCI - Oil Change Interval
PCM - Powertrain Control Module (the brain, also called ECU)
PSI - Pounds per Square Inch. Indication of pressure (mainly for the tire).
SOHC - Single OverHead Camshaft
SAB/SCAB - Side Air Bags/Side Curtain Air Bags
SRS - Supplemental Restraint System (Air Bags)
TCS - Traction Control System
VCM - Variable Cylinder Management. Ability to shut off the rear bank of cylinders under low load conditions to maximize fuel mileage. Integrates with Active Noise Cancellation (ANC) and Active Control Engine Mount System (ACM) to make the system transparent to the driver, with the exception of the green “ECO” light on the gauge cluster. (Hybrid only)
VSA - Vehicle Stability Assist (helps curb skidding)
VTEC - Variable valve Timing Electronically Controlled
XM - Satellite Radio
Model History
For 2003, Honda releases a completely redesigned Accord. Like every other Honda, the new Accord comes to the fight in full battle gear, bringing with it a full assortment of features, options, advancements and innovations. From the bargain basement DX model to the fully loaded EX V6 Navi, everyone can find a trim level that's right for their price range.
Tech Specs on the 7th gen Accord's chassis from Honda's website.
Tech Specs on the 7th gen Accord's drivetrain (Part 1)
Tech Specs on the 7th gen Accord's drivetrain (Part 2)
Tech Specs on the 7th gen Accord's drivetrain (Part 3)
Trim Levels and Features
2003
Three basic trim levels are offered on the Accord: DX, LX and EX. Available only as a sedan, the DX is the value model, coming standard with items considered luxuries just a few years ago. Among them, AM/FM/CD, power windows, tilt AND telescope steering, intermittent wipers, 15" steel wheels with full wheel covers, four wheel ABS, and dual front airbags.
The LX adds to that impressive list with air conditioning, cruise control, power side view mirrors, power locks with keyless entry, upgraded interior fabric, optional side airbags, and more speakers for the audio system. Outside, it is easily distingused by its 7 spoke wheel covers, body color moldings/mirrors/door handles, chrome trim surrounding the windows, and more available colors. The LX V6 makes side airbags standard, adds a standard 5-speed automatic, 16" steel wheels with 7-spoke wheel covers, 4 wheel disc brakes, anti-theft system, traction control, front side airbags, 8-way power drivers seat, 6-disc in dash CD changer, and of course the V6 (with dual chrome exhaust tips on the Coupe).
Stepping up to the EX model, you get polished 16" 5-spoke alloy wheels, painted side skirts, 4 wheel disc brakes with Electronic Brake Force Distribution, power moonroof with tilt, adjustable driver seat lumbar support and power height adjustment, anti-theft system, side air bags, steering wheel mounted audio controls, upgraded interior trim, and a 6-disc in dash CD changer. Available options include leather trim (includes automatic dual zone climate control, heated front seats with 8 way power driver seat, and side airbags), Honda's Navigation System (available only with leather, includes trip computer), and side curtain airbags (available only with leather). The V6 adds a standard 5-speed automatic, Home-Link transmitter, standard leather interior, traction control, and unique 16" 7-spoke polished alloy wheels, and dual chrome exhaust tips on the Coupe. A 6-speed manual transmission was offered as a no cost option for the EX V6 Coupe only, bringing a 180 watt premium audio system, red V6 badging, elegant silver 17" split 5-spoke wheels, perforated leather and faux carbon fiber interior trim along with it.
For 2004, the Accord stayed more or less the same. XM Satellite Radio and side curtain air bags became standard on models with leather interiors (EX-L, EX V6).
For 2005, the Accord received a slight update. The sedan rear lights became all red with the exception of the reverse lights. All models received standard front side airbags and side curtain airbags. LX and LX V6 models received new 6 spoke wheel covers and the EX V6 received restyled thicker 7-spoke polished alloys. The LX-SE and LX-SE V6 trim package also makes its debut on the Accord Coupe, consisting of EX alloy wheels (engine dependent, ie. LX-SE V6 gets EX V6 wheels), a flush trunk mounted spoiler, and painted side skirts underneath the doors. The Accord Hybrid also debuts with a 255HP 3.0L V6 with IMA, VCM, ANC, and ACM. Available only as a sedan, it comes standard with a lip spoiler, unique 16" aerodynamic alloys, unique exterior colors, yet curiously has no spare tire (a can of Fix-A-Flat and gloves instead) or sunroof. The interior is differentiated by a slightly modified gauge cluster with an IMA gauge to show whether the electric motor and battery are assisting or being charged. The cubby hole underneath the climate controls is also made considerably smaller, why is anyone's guess. A Navigation System remains optional.
For 2006, the Accord received a nice makeover. The front and rear fascias were changed, as was the front grille, along with completely new taillamps and revised badging for both the coupe and sedan. Engines are updated to 166HP for the 4 cylinder with DBW (increase of 6HP) and 244HP for the 6 cylinder (increase of 4). 4 cylinder EX models received split 5-spoke 16" polished alloys, while all V6 models except the Hybrid and 6-speed receive polished 17" 9-spoke alloys. The 6-speed option makes its way over to the sedan, and all 6-speeds get polished 17" 5-spoke alloy wheels. The instrument cluster is updated slightly across the board, as is the shift knob on automatic models. The Hybrid debuts later in the model year, with 253HP and a sunroof, along with a significant drop in mileage. The Hybrid's gauge cluster also receives a uniquely colored gauge cluster to differentiate it from the rest of the Accord sedans. The DX trim is dropped in favor of the new VP, now with power locks and cruise control standard, along with the normal side air bags and side curtain air bags. The LX-SE trim is dropped from the Coupe lineup and added to the Sedan lineup, adding a 6-disc CD changer, EX 16" alloys and 4 wheel disc brakes w/ EBD. This time around, the LX-SE trim is limited to the 4 cylinder engine. All models receive DRL's and the Maintenance Minder system. All V6's receive Vehicle Stability Assist (VSA) to complement the traction control system. The optional Navigation System is updated with 4th generation GPS software/interface, improving usability and features.
For 2007, the Accord carries over relatively unchanged, since 2006 was the Accord's year for the mid-model change (MMC). Several minor changes are made to trim lines. An SE V6 model is added, slotting in below the LX V6. SE V6 buyers have to forego the power drivers seat, power moonroof, heated side mirrors, and ambient lighting, but they also get to keep an extra $1850 in the bank. All EX V6 trim lines are also renamed EX-L V6, which adds a 4 way power passenger seat this year. All coupe models now come with alloy wheels.
Drivetrain
Two engines are offered on the 7th generation Accord. The 4 cylinder model (DX, LX, EX) receives a state of the art K-series engine, a far cry from the ancient F-series engine (tracing its roots back to the 1990 Accord) of the previous generation. Displacing 2.4 liters, the engine utilizes DOHC i-VTEC to help it produce 160HP and 161lb-ft of torque. More amazingly, this engine also manages to achieve great fuel mileage (26/34 MT, 24/33 AT) and is available with a PZEV emissions rating. Maintenance requirements are also lowered. Oil changes are now stretched out to 10,000 miles, spark plugs aren't due for 110,000 miles, and unlike the belts of previous Honda's, the timing chain never needs to be replaced. The engine received an update for 2006 (including the addition of DBW), checking in at 166HP under the new SAE J1349 test standards. The K24 can be mated to a 5-speed manual or an optional 5-speed automatic.
The real news lies in the 6 cylinder model (LX, EX). Although not a fresh design like the K24, the J-series carries over from the 6th generation with major modifications to help it compete with the Camry, Altima and Mazda6. Drastic changes to the intake path, valvetrain and an integrated exhaust manifold helps the buttery smooth 3.0 liter engine to produce 240HP and 212lb-ft of torque. Spark plugs aren't due for change until 105K, but the oil still needs to be replaced every 7500 miles. For 2006, the engine received a 4 horsepower boost under the new SAE J1349 test standards. The J30 can be mated to a 5-speed automatic or a no cost option 6-speed manual (see Trim Levels for specifics)
The Hybrid model (sedan only) adds a 15HP electric motor to the 6 cylinder, putting it at 255HP. Gains in fuel economy were not the main priority as much as the added torque of the electric motor around town and during passing maneuvers. A redesigned 5-speed automatic was installed in order to fit the electric motor, with regenerative braking as an added bonus.
Maintenance Items
These items are for the 2003-2005 models. Please confirm that these work with Gen7.5 models (2006+)
2006-2007 Accords use MMS and can disregard the recommended intervals listed below.
Air Cleaner - Replace @ 30K normal conditions, @ 15K dusty conditions
I4 - 17220-RAA-A00
V6 - 17220-RCA-A00
V6 Air Cleaner Replacement
Automatic Transmission Fluid - Replace @ 120K or 6 years normal conditions, @ 60K or 3 years severe conditions
I4 drain and fill - 3.0 quarts - DIY
V6 drain and fill - ?
ATF Filter - Unspecified interval
I4 - 25430-PLR-003 - More Info
V6 - 25450-RAY-003 - More info
Battery - As needed
I4 - 31500-SR1-100M
V6 - 31500-SL5-100M
Brake Pads/Shoes - As needed
I4 Front - 45022-SDA-A10
I4 Front (J VIN) - 45022-SDC-A10
I4 Rear Disc (Sedan only) - 43022-S84-A50
I4 Rear Disc (J VIN Sedan, all Coupe) - 43022-SV4-G22
I4 Rear Drum - 43053-SM4-A00
V6 Front (excl. 6MT, Hybrid) - 45022-SDB-A10
V6 6MT Front - 45022-SEA-J11
V6 Hybrid Front - 45022-SDR-A00
V6 Rear (excl. J VIN Sedan, Hybrid, Coupe) - 43022-S84-A50
V6 Rear (J VIN Sedan, Hybrid, all Coupe) - 43022-SV4-G22
Front Brake Pads Replacement (disc brakes)
Rear Brake Pads Replacement (disc brakes)
Rear Brake Shoes Replacement (drum brakes)
Cabin Air Filter - Every 30K or two years
80292-SDA-A01
80290-SDC-A01 (J VIN sedan - 2x the price but should be the same as above)
Cabin Air Filter Replacement
Drain Plug Crush Washer - Every respective fluid change
Oil - 94109-14000
AT Fluid Drain Plug - 90471-PX4-000
MT Fluid Drain Plug - 94109-14000
Fluid Capacities
I4 Crankcase Oil (MT/AT) - 5.3 / 5.2 quarts *Used for new/rebuilt engine only
I4 Oil change and filter - 4.4 quarts
I4 Coolant System (MT/AT) 7.2 / 7.1 quarts
V6 Crankcase Oil - 5.3 quarts *Used for new/rebuilt engine only
V6 Oil change and Filter - 4.5 quarts
V6 Coolant System (MT/AT) - 8.9 / 8.4 quarts
Light Bulbs
Front
Headlight Low Beam - 9006
Headlight High Beam - 9005
Front turn signal - 1157
OEM Foglight - H11
Rear
Tail lamp (Sedan) - 194
Tail lamp (Coupe) - 7443
Stop lamp - 7443
CHMSL (3rd brake light) - 7440
Reverse Lamp (Sedan) - 7440
Reverse Lamp (Coupe) - 921
Rear turn signal (Coupe) - 7440
Rear turn signal (Sedan) - 7440A
License Plate lamp - 194
Interior
Ashtray bulb - 74
Courtesy lights (doors) - 168
Trunk light - 168
Oil Filter - Every 20K or 1 year (I4), Every 15K or 1 year (V6)
15400-PLM-A01 (new Filtech, US market)
15400-PLM-A02 (new Honeywell/Fram, Canadian market)
15400-PCX-004 (old Toyo Roki, specified for S2000 only but assumed usable on all)
15400-P0H-305 (old Filtech, US market, no longer in production)
Spark Plug - Every 110K (I4), Every 105K (V6)
I4 - 9807B-56A7W (NGK IZFR6K13) / 9807B-56A5W (Denso SKJ20DR-M13)
V6 - 9807B-5615W (Denso SKJ20DR-M11)
Proper spark plug gap
Wipers - Every 6 months, 6000 miles or as needed
Wiper Blade Driver Side - 76620-SDA-A01
Wiper Blade Passenger Side - 76630-SDA-A01
Wiper Insert Driver Side - 76622-SDA-A01
Wiper Insert Passenger Side - 76632-SDA-A01
Problem Areas
http://www.driveaccord.net/forums/showthread.php?t=3129
http://www.driveaccord.net/forums/showthread.php?t=2025
2) Radio Problems
http://www.driveaccord.net/forums/showthread.php?t=4899
http://www.driveaccord.net/forums/showthread.php?t=4413
http://www.driveaccord.net/forums/showthread.php?t=1906
http://www.driveaccord.net/forums/showthread.php?t=2286
http://www.driveaccord.net/forums/showthread.php?t=9837 *Warranty Extension
3) Radio/Headunit Removal
http://www.driveaccord.net/forums/showthread.php?t=4560
http://www.driveaccord.net/forums/showthread.php?t=2383
4) A-Pillar/Window rattles
http://www.driveaccord.net/forums/showthread.php?t=4885
http://www.driveaccord.net/forums/showthread.php?t=4726
http://www.driveaccord.net/forums/showthread.php?t=4153
http://www.driveaccord.net/forums/showthread.php?t=4934
http://www.driveaccord.net/forums/showthread.php?t=6456
http://www.driveaccord.net/forums/showthread.php?t=3132
5) Brake vibrations
http://www.driveaccord.net/forums/showthread.php?t=4352
http://www.driveaccord.net/forums/showthread.php?t=2729
http://www.driveaccord.net/forums/showthread.php?t=3804
http://www.driveaccord.net/forums/showthread.php?t=408
http://www.driveaccord.net/forums/showthread.php?t=805
6) Premature Upholstery wear
http://www.driveaccord.net/forums/showthread.php?t=4959
http://www.driveaccord.net/forums/showthread.php?t=4861
http://www.driveaccord.net/forums/showthread.php?t=2241
http://www.driveaccord.net/forums/showthread.php?t=2190
http://www.driveaccord.net/forums/showthread.php?t=1614
http://www.driveaccord.net/forums/showthread.php?t=968
http://www.driveaccord.net/forums/showthread.php?t=174
http://www.driveaccord.net/forums/showthread.php?t=4852
http://www.driveaccord.net/forums/showthread.php?t=4391
http://www.driveaccord.net/forums/showthread.php?t=5029
http://www.driveaccord.net/forums/showthread.php?t=4519
http://www.driveaccord.net/forums/showthread.php?t=3719 *Maintenance Minder
http://www.driveaccord.net/forums/showthread.php?t=8256 *Maintenance Minder
10) Oil Consumption
http://www.driveaccord.net/forums/showthread.php?t=5066
http://www.driveaccord.net/forums/showthread.php?t=3519
http://www.driveaccord.net/forums/showthread.php?t=2403
http://www.driveaccord.net/forums/showthread.php?t=5012
http://www.driveaccord.net/forums/showthread.php?t=86
http://www.driveaccord.net/forums/showthread.php?t=3207
http://www.driveaccord.net/forums/showthread.php?t=3253
http://www.driveaccord.net/forums/showthread.php?t=5050
http://www.driveaccord.net/forums/showthread.php?t=3518
http://www.driveaccord.net/forums/showthread.php?t=4839
http://www.driveaccord.net/forums/showthread.php?t=4559
http://www.driveaccord.net/forums/showthread.php?t=4550
http://www.driveaccord.net/forums/showthread.php?t=4013
http://www.driveaccord.net/forums/showthread.php?t=4367
http://www.driveaccord.net/forums/showthread.php?t=1810
http://www.driveaccord.net/forums/showthread.php?t=4348
http://www.driveaccord.net/forums/showthread.php?t=1266
http://www.driveaccord.net/forums/showthread.php?t=3529
http://www.driveaccord.net/forums/showthread.php?t=3025
http://www.driveaccord.net/forums/showthread.php?t=6875
14) Trunk Leak
http://www.driveaccord.net/forums/showthread.php?t=4800
http://www.driveaccord.net/forums/showthread.php?t=329
http://www.driveaccord.net/forums/showthread.php?t=4464
http://www.driveaccord.net/forums/showthread.php?t=3749
http://www.driveaccord.net/forums/showthread.php?t=3361
http://www.driveaccord.net/forums/sh...ad.php?t=20784
http://www.driveaccord.net/forums/sh...t=3rd+gear+tsb
Modifications
17mm bar parts needed:
1 of 52300-SEP-A03
2 of 52306-SEP-A02
2 of 52308-S3M-A00
20mm bar parts needed:
1 of 52300-SEP-A11
2 of 52306-SEP-A11
2 of 52308-S3M-A00
http://www.sunnysideacura.com/
http://www.driveaccord.net/forums/showthread.php?t=5086
http://www.driveaccord.net/forums/showthread.php?t=5072
http://www.driveaccord.net/forums/showthread.php?t=4812
http://www.driveaccord.net/forums/showthread.php?t=1974
http://www.driveaccord.net/forums/showthread.php?t=1140
Lots more – do a search!
http://www.driveaccord.net/forums/showthread.php?t=5055
http://www.driveaccord.net/forums/showthread.php?t=3592 – Neuspeed/aftermarket
http://www.driveaccord.net/forums/showthread.php?t=2575
http://www.driveaccord.net/forums/showthread.php?t=3075
http://www.cardomain.com/ride/281873/5 - DIY guide
http://www.driveaccord.net/forums/showthread.php?t=2839
4) Wheels
http://www.driveaccord.net/forums/showthread.php?t=1046
http://www.driveaccord.net/forums/showthread.php?t=4005
http://www.driveaccord.net/forums/showthread.php?t=3851
http://www.driveaccord.net/forums/showthread.php?t=3637 Wheel offset
http://www.driveaccord.net/forums/showthread.php?t=5024
http://www.driveaccord.net/forums/showthread.php?t=4473
http://www.driveaccord.net/forums/showthread.php?t=8245
5) Illuminated Steering Wheel Controls
http://www.driveaccord.net/forums/sh...5&page=4&pp=15
http://www.driveaccord.net/forums/showthread.php?t=1814
6) Inspire Headlights/foglights
http://www.driveaccord.net/forums/showthread.php?t=2199
http://www.driveaccord.net/forums/showthread.php?t=4112
http://www.driveaccord.net/forums/showthread.php?t=5453
http://www.driveaccord.net/forums/showthread.php?t=8145
7) Foglights
http://www.driveaccord.net/forums/showthread.php?t=5092
http://www.driveaccord.net/forums/showthread.php?t=3179
http://www.driveaccord.net/forums/showthread.php?t=3238
http://www.driveaccord.net/forums/showthread.php?t=1982
http://www.driveaccord.net/forums/showthread.php?t=2248
8) HFP package
http://www.driveaccord.net/forums/showthread.php?t=4731
http://www.driveaccord.net/forums/showthread.php?t=5084
http://www.driveaccord.net/forums/showthread.php?t=2588
http://www.driveaccord.net/forums/showthread.php?t=2594
9) Exhaust Tips
http://www.driveaccord.net/forums/showthread.php?t=2591
http://www.driveaccord.net/forums/showthread.php?t=2152
http://www.driveaccord.net/forums/showthread.php?t=4215
http://www.driveaccord.net/forums/showthread.php?t=3424
http://www.driveaccord.net/forums/showthread.php?t=3003
http://www.driveaccord.net/forums/showthread.php?t=3192
http://www.driveaccord.net/forums/showthread.php?t=661
http://www.driveaccord.net/forums/showthread.php?t=2389
http://www.driveaccord.net/forums/showthread.php?t=2324
http://www.driveaccord.net/forums/showthread.php?t=1258
http://www.driveaccord.net/forums/showthread.php?t=6127
http://www.driveaccord.net/forums/showthread.php?t=3345
http://www.driveaccord.net/forums/showthread.php?t=2778
http://www.driveaccord.net/forums/showthread.php?t=2621
http://www.driveaccord.net/forums/showthread.php?t=4218
http://www.driveaccord.net/forums/showthread.php?t=2149
http://www.driveaccord.net/forums/showthread.php?t=4643
http://www.driveaccord.net/forums/showthread.php?t=4931
http://www.driveaccord.net/forums/showthread.php?t=2766
http://www.driveaccord.net/forums/showthread.php?t=3208
http://www.driveaccord.net/forums/showthread.php?t=2646
http://www.driveaccord.net/forums/showthread.php?t=4991
http://www.driveaccord.net/forums/showthread.php?t=4179
http://www.driveaccord.net/forums/showthread.php?t=2088
15) Aux input (Also refer to Problem Areas > 3) Radio Removal)
http://www.driveaccord.net/forums/showthread.php?t=2989
http://www.driveaccord.net/forums/showthread.php?t=2780
http://www.driveaccord.net/forums/showthread.php?t=4684
http://www.driveaccord.net/forums/showthread.php?t=5399
http://www.driveaccord.net/forums/showt ... 4091*03-05 Navi
http://www.driveaccord.net/forums/showt ... t=6424*06+ Navi
http://www.driveaccord.net/forums/showt ... 8198*03-05 "OK" bypass
17) Detailing
http://www.driveaccord.net/forums/showthread.php?t=4981
http://www.driveaccord.net/forums/showthread.php?t=3509
http://www.driveaccord.net/forums/showthread.php?t=2046
http://www.driveaccord.net/forums/showthread.php?t=3714
http://www.driveaccord.net/forums/showthread.php?t=4082
http://www.driveaccord.net/forums/showthread.php?t=3508
http://www.driveaccord.net/forums/showthread.php?t=4041
http://www.driveaccord.net/forums/showthread.php?t=922
18) Clear Bra
http://www.driveaccord.net/forums/showthread.php?t=3541
http://www.driveaccord.net/forums/showthread.php?t=2481
http://www.driveaccord.net/forums/showthread.php?t=2701
http://www.driveaccord.net/forums/showthread.php?t=102
http://www.driveaccord.net/forums/showthread.php?t=2664
http://www.driveaccord.net/forums/showthread.php?t=4779
19) Speakers
http://www.driveaccord.net/forums/showthread.php?t=4784
http://www.driveaccord.net/forums/showthread.php?t=4918
http://www.driveaccord.net/forums/showthread.php?t=4143
http://www.driveaccord.net/forums/showthread.php?t=4045
http://www.driveaccord.net/forums/showthread.php?t=4971
20) Tires
http://www.driveaccord.net/forums/showthread.php?t=4736
http://www.driveaccord.net/forums/showthread.php?t=2955
http://www.driveaccord.net/forums/showthread.php?t=3587
http://www.driveaccord.net/forums/showthread.php?t=1802
http://www.driveaccord.net/forums/showthread.php?t=2510
http://www.driveaccord.net/forums/showthread.php?t=3219
21) Winter Tires
http://www.driveaccord.net/forums/showthread.php?t=1291
http://www.driveaccord.net/forums/showthread.php?t=3650
http://www.driveaccord.net/forums/showthread.php?t=4388
22) Oil
http://www.driveaccord.net/forums/showthread.php?t=3338
http://www.driveaccord.net/forums/showthread.php?t=4371
http://www.driveaccord.net/forums/showthread.php?t=3542
http://www.driveaccord.net/forums/showthread.php?t=3578
http://www.driveaccord.net/forums/showthread.php?t=3275
23) Oil Filter
http://www.driveaccord.net/forums/showthread.php?t=8988 *Filter bypass/S2K filter
http://www.driveaccord.net/forums/sh...9&page=3&pp=15 *Old/new filter
24) Tire Pressure
http://www.driveaccord.net/forums/showthread.php?t=3166
http://www.driveaccord.net/forums/showthread.php?t=806
25) Gas
http://www.driveaccord.net/forums/showthread.php?t=3291
http://www.driveaccord.net/forums/showthread.php?t=4137
http://www.driveaccord.net/forums/showthread.php?t=3711
http://www.driveaccord.net/forums/showthread.php?t=3533
http://www.driveaccord.net/forums/showthread.php?t=2933
http://www.driveaccord.net/forums/showthread.php?t=2981
TSX Intake Manifold
http://www.driveaccord.net/forums/showthread.php?t=8999
Parts
1) Part Sources (OEM)
http://www.hondacuraworld.com
http://www.hondapartsdeals.com
http://www.collegehillshonda.com
http://www.handaaccessories.com
http://www.hondaautomotiveparts.com
http://www.cheaphondaparts.com
http://www.hardtopguy.com
http://www.ebay.com
2) Part Sources (Aftermarket)
http://www.tirerack.com
http://www.modacar.com
http://www.procarparts.com
http://www.ebay.com
http://www.nopionline.com
http://www.groupbuycenter.com
http://www.coximports.com
http://www.buybrakes.com
2003-2007 Common Torque Specs
(all torque specifications are in ft-lbs unless otherwise noted)
Wheel Lug Nuts..............80 (retorque after 15 miles if new alloys)
Oil Drain Plug (I4)............33
Oil Drain Plug (V6)...........29
AT filler bolt...................33
AT drain bolt..................36
Spark plugs....................13
Front caliper bolts...........26
Rear caliper bolts............17
Rear swaybar bracket......16
Detailed list of CM STATS
« Reply #1 on: December 07, 2009, 05:57:30 PM »
OMG where have you been all my life. lol Great post and very nice find
« Reply #2 on: December 07, 2009, 09:27:05 PM »
Holy shit Bill. You spent quite a bit of time copying and pasting didn't you?
« Reply #3 on: December 07, 2009, 09:30:40 PM »
Nice man.  Tons of info.
Icebox pfffft.
« Reply #4 on: December 08, 2009, 06:57:32 AM »
sticky?
« Reply #5 on: December 08, 2009, 07:57:46 AM »
Good idea Dave. Congrats Bill. You just earned yourself a sticky.
« Reply #6 on: December 08, 2009, 08:19:39 AM »
Very nice information Thank you for posting this.
« Reply #7 on: December 08, 2009, 08:48:53 AM »
Wow, I need to make a thread like this, maybe you guys will hump my leg too....
Seriousily, alot of awesome information Bill, good job.
« Reply #8 on: December 08, 2009, 09:43:45 AM »
You'd like a bunch of men to hump your leg wouldn't you Jeremy?
« Reply #9 on: December 08, 2009, 01:48:20 PM »
WOW  :clap:
« Reply #10 on: December 08, 2009, 04:04:28 PM »
Hell Yeah, a sticky.
fabulous010 pfffft.
« Reply #11 on: April 10, 2010, 07:53:57 PM »
Congrates bill on your first sticky. Awesome find
« Last Edit: July 02, 2010, 12:20:43 PM by Jeff » Logged
« Reply #12 on: April 14, 2010, 12:07:56 PM »
I added a link to the bottom of this post containing some general stats about the CM.
redHFPcm7
redHFPcm7 pfffft.
« Reply #13 on: August 03, 2010, 05:38:36 PM »
Nice!!! will be visiting this quite alot for general info lol
« Reply #14 on: August 04, 2010, 02:15:10 AM »
Hence why its called General Information.  laugh
