May 31, 2026, 08:44:23 PM
20
21
22
23
31
Topic: The Only Fog Light Thread You Should Ever Post In (Read 251730 times)
Re: Inspire foglight wiring help
Reply #300 on:
May 18, 2011, 02:01:26 AM »
^This.
Especially since the OEM harness is straight PnP and you can find the OEM instructions online. Shouldn't take you more than an hour and that's including pulling off the front bumper.
Lu Mcfly
Reply #301 on:
May 18, 2011, 07:31:36 PM »
yea i think im going to go ahead and order it...cheapest place i saw it was on majestic...any other sites?
BTW since i never had OEM harness and connection i never had a problem with having the high beams and fog lights on at the same time...can i still do the same with the OEM connectivity?
Mr. HFP
Reply #302 on:
May 18, 2011, 07:41:34 PM »
Lu
Order from
South Bay Honda
and get the following part numbers... I would call them an make sure that the parts below will work for your year since I have a 2003. I know the wiring harness maybe different! 1-877-475-1145
Engine compartment harness, cabin harness, oem switch, relay 1 and relay 2 all PNP (plug and play) literally takes like 45 minutes to do!
08V31-SDA-10030
08V31-SDA-10031
08V31-SDA-1M035
39795-SB2-003 RC-2201
39796-SXO-003 RC-2402
Reply #303 on:
May 18, 2011, 10:04:44 PM »
Yeah, what year is your car Lu?
Lu Mcfly
Reply #304 on:
May 19, 2011, 07:33:02 PM »
I have an 06 Tim.
Thanks for the p/n Billy, ill look into that...as far a s the oem switch i have that.
Mr. HFP
Reply #305 on:
May 19, 2011, 08:16:32 PM »
Quote from: Lu Mcfly on May 19, 2011, 07:33:02 PM
I have an 06 Tim.
Call them and tell them you need the (2) relays, which those are the part numbers for the 2003 model!
Reply #306 on:
May 20, 2011, 06:54:57 AM »
Billy, the 06 has one relay. I'll pull up a parts list of what you need later today or tomorrow Lu. Whatever you do, don't get the parts Billy said to get because they are different from what you need.
Reply #307 on:
May 20, 2011, 07:26:57 AM »
Yeah, all I used was kne relay.
Lu Mcfly
Reply #308 on:
May 20, 2011, 10:35:55 AM »
Yeah because I only remember having one relay in the hood. But I do have another under the steering wheek by the fuse bix thats linked to the oem switch. Maybe thats why Billy said two relays.
Mr. HFP
Reply #309 on:
May 20, 2011, 10:46:12 AM »
I didn't have a relay under the steering wheel. There was a plug down there that I plugged the switch too, but that was about it.
Reply #310 on:
May 20, 2011, 03:40:08 PM »
Billy gave you the correct information for the wrong car. Trust me when I tell you that your wiring harness should only have one relay. You may have something else under your dash because it's aftermarket, or you may have mistaken an electrical connector for a relay. Whatever you do, get the wiring harness for your car. Here are the parts you need:
08V31-SDA-10130 - #5
08V31-SDA-10131 - #6
08V31-SDA-1M035 - #7
39795-SB2-003 - #8
Reply #311 on:
May 20, 2011, 09:18:13 PM »
I try to be helpful when I can, I did however say that the parts were for an 03-05... wasn't sure what year Lu had!
Reply #312 on:
May 20, 2011, 11:17:31 PM »
That's why I asked what year he had before giving advice.
no homo
Lu Mcfly
Reply #313 on:
May 21, 2011, 06:29:37 AM »
This is the same diagram I was referencing from thats whys it was wierd about the two relays...but thnx again guys...ill order these parts asap...
Mr. HFP
Reply #314 on:
May 27, 2011, 11:22:54 PM »
Both my inspire fogs failed me tonight. Don't know if it's a relay or fuse issue. I'll have to check it out tomorrow. Maybe an issue with the HiD's? Will update as soon as I find an answer.
20
21
22
23
31
