August 13, 2026, 02:02:01 PM
21
22
23
24
31
Topic: The Only Fog Light Thread You Should Ever Post In (Read 259759 times)
Re: Inspire foglight wiring help
Reply #315 on:
May 28, 2011, 10:41:02 AM »
Quote from: gargantula99 on May 27, 2011, 11:22:54 PM
Both my inspire fogs failed me tonight. Don't know if it's a relay or fuse issue. I'll have to check it out tomorrow. Maybe an issue with the HiD's? Will update as soon as I find an answer.
What the.... check all connections Nelson, if you wired them according to the Honda instructions you should be fine. Hopefully...
Reply #316 on:
May 28, 2011, 10:55:08 AM »
They worked fine for weeks before the hid's Were put in. I'm gonna shoot you a text.
Reply #317 on:
May 28, 2011, 02:55:45 PM »
I'm thinking it's the relay that blew. Any idea how to check a relay? I looked at the fuse guides and didn't find one that said fog light so I checked them all one by one. Good thing too bc I was missing a fuse. No idea how that happened. Anyways, thoughts, advice, is always welcome.
Lu Mcfly
Reply #318 on:
May 30, 2011, 03:31:35 PM »
Yea i think it might just be fuse. Or maybe the power to the HID's since it happened after trhe HIDs were installed
Mr. HFP
Reply #319 on:
May 30, 2011, 03:49:31 PM »
Anybody know how to test a relay? I hear it clicking when I push the switch. There's no fuse that I know of.
Reply #320 on:
May 30, 2011, 05:56:52 PM »
Quote from: gargantula99 on May 30, 2011, 03:49:31 PM
I think in your engine bay fuse box it is Fuse Slot #10... takes a 20 amp fuse. I will have to check when I get home but i'm sure that's the one!
Lu Mcfly
Reply #321 on:
June 03, 2011, 01:05:36 AM »
It is #10 fuse slot because I just put a 20amp fuse in mine as well....
So I finally got the oem parts for the fog lights and using the dealer installation guide I installed.....but it doesnt work...the fog light switch light doesnt even come on as if theres no power...need help...
Mr. HFP
Reply #322 on:
June 03, 2011, 08:17:47 AM »
I'll have to double check that fuse. Even though I think it's the blue wire at the switch that's my issue. I cut that once, not a good idea.
Reply #323 on:
June 03, 2011, 04:59:28 PM »
Quote from: Lu Mcfly on June 03, 2011, 01:05:36 AM
Did you ground the harness going to the passenger foglight...? Follow the harness it should be grounded at the hood latch. Did you ground the foglight switch harness under the steering column...? 2 things you could check!
Quote from: gargantula99 on June 03, 2011, 08:17:47 AM
...your a lost case
seriously though just solder the blue wire back together and wrapped it in electrical tape as a precaustion. As to what else to do i'm clueless at this point
Reply #324 on:
June 03, 2011, 05:44:21 PM »
LoL! Double checked the fuse, it's was blown. Billy let me borrow your soldering iron.
Reply #325 on:
June 05, 2011, 05:28:17 PM »
Double checked the wire at the switch. I did solder and heat shrink it. So that's not the issue. I'm at a loss.
Fuck HID's in my fogs, I'm going back to the stock setup next week when I'm home and I can take the bumper off.
Reply #326 on:
June 05, 2011, 06:33:21 PM »
Quote from: gargantula99 on June 03, 2011, 05:44:21 PM
Loco, OoH I don't own a soldering iron... Radio Shack FTMFW!
Lu Mcfly
Update pics on foglights, front grill and plate locator
Reply #327 on:
June 07, 2011, 01:16:51 PM »
Just thought I'd give an update on the foglight situation...So i installed all the OEM foglight harness's myself but still had a problem so i decided to take it to a real electrician where he then told me it was a simple mistake and fixed it with an extra relay and direct wire to the fogs so they can go on by themselves.
6k's but look more like 8K's in the picture.
Switchback LED's
Also moved the license plate to the other side but couldn't do anything about the grill fitment and placed a HFP emblem on front grill. What do you guys think?
Mr. HFP
Re: Update pics on foglights, front grill and plate locator
Reply #328 on:
June 07, 2011, 01:34:37 PM »
Looks good! I like the blue turns!
What's that weird blue blotches in like the first 4 pics? Glare from the HIDs? And your right, they def look just like my 8000ks in the first pics without the headlights on.
Lol @ the last two pics, it looks like the car is leanin to the left... from the weight of the license plate
Lu Mcfly
Reply #329 on:
June 07, 2011, 01:42:20 PM »
Haha yea it does...plate does seem a bit off...but as far as the blue blotches idk just noticed it when i posted them up...must be the glare. Thanks on the reply
Mr. HFP
21
22
23
24
31
