October 30, 2026, 12:23:48 AM
Author Topic: How To: TSX Side Mirror On Coupes  (Read 29156 times)
« on: February 06, 2009, 09:57:59 PM »
Parts Required
  • Pair of TSX side mirrors in any color
  • Pair of Accord side mirror(can use the one on the car or buy a spare)
Tools Required:
  • Phillips and flathead screw drivers
  • Dremel or similar cutting tool
  • ratchet or similar with 8mm socket
  • Alot of patience
  • Soldering iron and wire
  • Electrical tape
First we start  by removing the stock mirror and open it apart.
1> Pry out the cover in the picture, it is held in place by clips so gently pull it out
2> After you remove it, this is how its gonna look
3> Disconnect the black connector from the white socket by pressing the clip in the bottom and pulling it away
4> Now remove the 3 bolts with 8mm socket but leave the top left one intact. The Bottom right screw needs to be removed by some pliers or small adjustably wrench cause the ratchet wont reach. From the outside of the car, gently pull out the mirror but dont pull it too hard. Also you will have to free the clips of the socket from the inside.
5> Mirror removed and ready for surgery
6> Remove these screws but be careful not to strip them
7>  Now cut the cable in the middle and remove the bracket from the mirror housing
8> Hold the assembly like shown and from one corner lift up the mirror and pry it out from the clip holding it and remove the mirror
9> Pop the silver tabs in the bottom to remove the plastic cover on the back that matches to the color of your car and completely remove the cover
10> Remove the 3 screws and one in the bottom of the base to remove the motor and motor bracket from the shell
11> Everything apart but dont throw anything away. Remove the white motor from the metal bracket.
12> Do the same on the TSX's mirror but keep track of the parts.
13> Accord's bracket(left) Vs the TSX(right). You need to cut the Accord's bracket and modify it to fit the TSX shell.
ROLO pfffft.
« Reply #1 on: March 16, 2009, 04:33:24 PM »
I've only seen a handfull of coupes w/ these mirrors... I love my TSX Mirrors wish I had done it sooner... (makes me feel like I'm in a Lexus or Mercedez) lol..
« Reply #2 on: March 16, 2009, 05:57:27 PM »
Quote from: "ROLO"
+1 it does make me feel like I'm something else.
ROLO pfffft.
« Reply #3 on: March 18, 2009, 09:14:17 AM »
Final Result should look like this
LiquidX
LiquidX pfffft.
« Reply #4 on: March 18, 2009, 05:21:53 PM »
MMMM....tasty, although i did the hybrid mirrors and saved my self a bunch of work....(sedan owner)
drey
drey pfffft.
« Reply #5 on: April 01, 2009, 04:15:00 PM »
i love this mod. arent the coupe mirrors and sedans the same?
didnt realize there was some work involved to do this mod. now im having second thoughts...
LiquidX
LiquidX pfffft.
« Reply #6 on: April 01, 2009, 06:37:29 PM »
No the bases of the coupe and the sedan are different.
drey
drey pfffft.
« Reply #7 on: April 01, 2009, 08:18:17 PM »
so is there any modifications to hook up the tsx mirrors on the accord sedan? or is it as simple as unplugging the wires and bolting up the tsx mirrors?
LiquidX
LiquidX pfffft.
« Reply #8 on: April 02, 2009, 12:26:33 AM »
You will have to drill another hole due to different mounting bolts on the tsx, then you will have to run the led wires to your turn signals. There are diys on mounting tsx mirrors to sedans, this one is for the coupe.
rjp6262
rjp6262 pfffft.
« Reply #9 on: April 08, 2009, 09:08:47 PM »
wouldn't the tl mirrors fit on the coupe? i remember reading somewhere that the bases for the coupe and the tl were the same.
LiquidX
LiquidX pfffft.
« Reply #10 on: April 09, 2009, 09:53:19 AM »
Negative, you will need to modify the bae of the tl mirrors. You have to pm thien on this one as he has done them on his coupe.
aavq85
aavq85 pfffft.
« Reply #11 on: April 25, 2009, 01:21:13 PM »
if u have a coupe is there a need to run any new wires?
Signature deleted for not following FORUM RULES
Paulius005 pfffft.
« Reply #12 on: May 01, 2009, 05:04:33 PM »
Could someone pull up the rest of that DIY? I remember there being more pics with a drawing on what to cut and what not.
Paulius San Jose, CA
LiquidX
LiquidX pfffft.
« Reply #13 on: May 01, 2009, 05:40:48 PM »
Quote from: "Paulius005"
Are you doing tsx mirrors? i can do a write up for you since i have hybrid mirrors on my 05 sedan, and i did tsx for my friend with an o6 exl coupe.
fabulous010 pfffft.
« Reply #14 on: June 26, 2009, 08:07:36 PM »
yes please!
