August 27, 2026, 07:22:44 AM
Brakes
Topic: How To: Acura Legend GS Sedan Dual Piston Caliper Swap (Read 167106 times)
InFuMoUs
Reply #75 on:
April 09, 2009, 04:55:19 PM »
Quote from: "AV6NHBP6SPD"
is it ok to paint top of rotor(where vents are, on side where its not contacting brake pads)? couse mine are rusted there and dont like it. want somehow protect them from rusing. i was gona use flat black high heat paint for that. or is there something special i can use? i know there are some rotors are covered with cryo or something that preven rust. is there something like that avaliable in a spray can or something?
Ya you can paint the top part where the vents are. The only part on the rotor that you shouldn't paint on is the area that the brakes grab onto. Any high heat paint would work just fine. The higher the heat resistance, the better I would think.
Steve -
Squad/
Team Crazy Creashunz
Reply #76 on:
April 09, 2009, 05:52:18 PM »
Not sure what you want the specs for, but here's everything:
Brake hose banjo fitting bolt - 25 ft/lbs
Caliper mounting bracket bolts
Front - 80 ft/lbs
Rear - 41 ft/lbs
Caliper mounting guide pins/bolts
Front
i4 - 26 ft/lbs
V6 - 37 ft/lbs
Rear - 17 ft/lbs
Master cylinder mounting nuts - 11 ft/lbs
Power brake booster mounting nuts - 115 inch/lbs
Wheel cylinder mounting bolts - 84 inch/lbs
Wheel speed sensor mounting bolt - 86 inch/lbs
Reply #77 on:
April 09, 2009, 08:11:07 PM »
ok brakes are done and broken in, boy do they grab. night and day difference
TIM, had to take shims off, no way calipers were gona fit on with shims on brake pads (green stuff and brembo blanks. just heads up
ill upload pics later tonight. packing old calipers to ship them back out to Sean
by the way. breaks squeak couse pads dont have shims on them. hopefully once they brake in i can put shims back on couse it doesnt fit with them on. probably too thick
Reply #78 on:
April 09, 2009, 09:52:45 PM »
Quote from: "suleman_manji"
get rebuilt. no questions asked.
used you risk the possibility that the piston is scarred/swollen/deformed plus the fact that over the years the rubber components wear down. so yeah... just get rebuilt. shouldn't be too much more expensive (for me it's ~40bucks each (loaded caliper) with a 50dollar core charge (which i don't have to pay lol))
Can you hook me up at this price? I need to upgrade my brakes after my accident I dont feel I have enought stopping power.
InFuMoUs
Reply #79 on:
April 09, 2009, 09:57:26 PM »
I thought Greenstuff pads had shims already built with it on.
Steve -
Squad/
Reply #80 on:
April 09, 2009, 10:38:24 PM »
Misha, you're going to want to use some of this stuff.
Anti-Squeal
Reply #81 on:
April 09, 2009, 11:46:44 PM »
Quote from: "InFuMoUs"
they do but with shims on GS calipers dont fit over new brake pads and rotors. had to take shims off for now.
Tim ill get that stuff tomorrow. deff need that, dont like having that sound
Reply #82 on:
April 10, 2009, 10:39:41 AM »
viewtopic.php?f=28&t=751
suleman_manji
Reply #83 on:
May 20, 2009, 01:19:35 AM »
or if you live near a mercedes benz dealership: stop by the parts dept. and ask the lady for some BG STOP SQUEAL(sp; its late). stuff works wonders (i mainly use it for the anoying squeaky brakes comebacks)
cheap too, like 3bucks. and sadly merc charges 60 dollars for the service (sanding the pads, appylying the graphite and reinstalling)
oh and no i cannot hook anyone up because i cant even hook myself up yet. none of my vendors can locate the left caliper.
T
X
Squad #
flick
r
fb
[img]http:
Reply #84 on:
September 16, 2009, 01:42:59 PM »
Don't mean to derail this thread, but from reading through I take it TSX and TL callipers do not fit our cars?
Reply #85 on:
September 16, 2009, 04:46:14 PM »
The TSX calipers aren't much of an upgrade if any at all. They are single piston calipers. The TL brembos are definitely an upgrade, and from what I know, you can get them to fit with minor modifications.
Reply #86 on:
September 16, 2009, 08:39:28 PM »
What is the primary advantage of multiple piston callipers? More even pad pressure? More power? Or do they simply let you use a larger brake pad?
Reply #87 on:
September 16, 2009, 08:43:58 PM »
Greater stopping power. It has the ability to increase the amount of pressure on the pads, and the pressure is applied more evenly. The Legend GS calipers are def. an awesome upgrade over stock.
Reply #88 on:
September 17, 2009, 10:56:24 PM »
What do you guys think about this person's opinion?
http://www.cb7tuner.com/vbb/showthread. ... readid=836
Reply #89 on:
September 17, 2009, 11:10:10 PM »
All I can tell you is not matter what that person thinks my car stops on a fucking dime since doing this upgrade. Tim, and other members have also said nothing but, good things.
