October 23, 2026, 01:08:41 PM
Brakes
14
15
Topic: How To: Acura Legend GS Sedan Dual Piston Caliper Swap (Read 172283 times)
Fanitron
Reply #210 on:
May 08, 2012, 10:45:34 PM »
Quote from: Rushzer0 on May 08, 2012, 04:36:08 PM
Hmmm.. We may have to work a little something out in the future.
^^what he said!
super425
Reply #211 on:
February 23, 2013, 09:41:10 PM »
So for this legend caliper will direct bolt on right no need to get an adapter to make it fit is that correct.
Reply #212 on:
February 23, 2013, 11:18:32 PM »
Correct.
super425
Reply #213 on:
February 23, 2013, 11:28:15 PM »
Thanks Tim.
super425
Reply #214 on:
February 23, 2013, 11:30:25 PM »
Is the Legend LS work as same as gs?
Reply #215 on:
February 23, 2013, 11:34:58 PM »
Yes, the calipers are the same part number between the LS coupe and GS sedan.
super425
Reply #216 on:
February 23, 2013, 11:37:02 PM »
Thanks gonna pick up the new caliper from a guy for 125
super425
Reply #217 on:
February 24, 2013, 09:59:02 PM »
So the center hole of the rotors will be bigger than our center bore right. And everything will be the same and wheels just bolt up just normal right.
Reply #218 on:
February 25, 2013, 02:52:57 PM »
Yes, they will bolt up correctly. Same bolt pattern as our Accords.
Reply #219 on:
February 25, 2013, 09:02:55 PM »
Isn't the 03-07 6-speed rotor the same size? Would be a better choice if it is since they are hub centric.
Re: Re: How To: Acura Legend GS Sedan Dual Piston Caliper Swap
Reply #220 on:
February 25, 2013, 09:51:15 PM »
I believe it was advised to use the Legend rotors if you have an i4, or use the 6 speed rotors if you have a v6. I was on the verge of doing the same, however I didn't want to take the chance of things not lining up due to any differences between the v6 and i4.
Reply #221 on:
February 25, 2013, 11:34:55 PM »
I tried both rotors. If you have a K24, the J30 rotors are not the correct offset. When I test fit the J30 rotors, they weren't centered in the caliper.
14
15
