November 08, 2026, 08:09:31 PM
Bolt Ons
15
16
17
18
20
Topic: TSX Intake Manifold DIY / Q & A (Read 318860 times)
Re: Re: TSX Intake Manifold DIY / Q & A
Reply #225 on:
June 25, 2012, 10:36:50 PM »
Degreaser, a hose, let it dry in the sun. That's what I did with mine when I got it off Tim.
Reply #226 on:
June 25, 2012, 10:44:56 PM »
You could do that and hit it with a wire wheel if you want to get it sparkling clean.
seiplentz
Reply #227 on:
September 24, 2012, 06:57:03 PM »
Well I installed my tsx im yesterday. The install went pretty smooth. I am feeling a little umph from it. I do have a little hesitation when you first hit the pedal. Has anybody else experienced this? My wife pretty much said if it keeps doing it I have to put the stock one back on
. I'm not sure if its a vacuum leak the idle is smooth and it accels smooth its just at the first 1/2 sec hit of the pedal. Any ideas? I also have SRI as well and thats it for mods.
Reply #228 on:
September 24, 2012, 09:36:19 PM »
My car does that, and I don't have a TSX im. Lol
Reply #229 on:
September 25, 2012, 12:03:35 AM »
Quote from: seiplentz on September 24, 2012, 06:57:03 PM
I never had this issue when I installed mine 2 years ago. Did you make sure it was installed correctly?
Reply #230 on:
September 25, 2012, 07:49:32 AM »
I think he may have a small leak somewhere, namely the throttle body gasket. Need more info on what gaskets were reused or replaced.
seiplentz
Reply #231 on:
September 25, 2012, 09:39:02 AM »
I reused both gaskets. It came apart pretty easy my car only has 55k on it. I also thought a small leak just wish I knew how to find such a small leak if there is one.
Reply #232 on:
September 25, 2012, 10:34:08 AM »
The one between the IM and the lower and upper is metal so its not a big deal. The TB one is some type of paper composite and prone to tears even tiny ones. Trying to find a leak for something like that is a bitch and the easiest thing to do is just replace that gasket.
seiplentz
Reply #233 on:
September 26, 2012, 09:05:00 PM »
Thanks for the input.. I found out my uncle who has a shop also has a smoke machine. So when I get a chance I am going to bring it up there to look for a leak with that. He also said that I could spray around gasket areas with some throttle body cleaner and if there is a leak the idle will change. The only problem I have with that method is that I powder coated the intake and I think throttle body cleaner has acetone in it which can fuck up powder coatings..
Reply #234 on:
September 27, 2012, 12:09:05 AM »
You could always re power coat it. I'd rather have a working intake manifold.
Reply #235 on:
September 27, 2012, 07:37:10 AM »
^This.
Reply #236 on:
November 02, 2012, 12:01:59 AM »
I started the guide, got stuck on one of the first steps when the phillips head got stripped... Should I dremel a slot into it and use a slot head?
Another question (I have 2007), on the left side of my plenum I have a small tube heading left. On the new TSX IM I don't have the same port on the left side, is this on the rear that needed to be relocated, as mentioned in the guide?
Reply #237 on:
November 06, 2012, 11:08:07 AM »
Bought the replacement screw, need to take a day out of this week to try again
super425
Reply #238 on:
January 22, 2013, 01:19:07 PM »
Alright will have my IM in this week or next but still debating between p2r gasket or hondata gasket for the injector base, and i am sure will be p2r IM gasket and TB gasket.
Reply #239 on:
January 22, 2013, 01:26:05 PM »
They're all pretty much the same stuff. I have a P2R gasket for my IM (no injector base on my car).
15
16
17
18
20
