November 08, 2026, 08:09:31 PM
Bolt Ons
14
15
16
17
20
Topic: TSX Intake Manifold DIY / Q & A (Read 318860 times)
Re: TSX Intake Manifold DIY / Q & A
Reply #210 on:
February 15, 2012, 11:04:27 PM »
You can bore your TB, or you can pick up a K20A2 TB and get an adapter. I think Karcepts may make one. Another option would be the Hybrid Racing 70mm TB, but you're going to need to machine the inlet of the TB and port match them, otherwise you're wasting your time and money.
Reply #211 on:
February 15, 2012, 11:35:41 PM »
Tim, I'm just curious, but do you think an 04-05 TSX intake manifold would work on an 06-07 Accord? I know the 04-05 TSX IM has the IACV notch, but the 06-07 Accord TB doesn't have one, so it would be blocking it off anyways. The only thing I can think of is the bore of the 04-05 TSX IM being too small to match the 06-07 Accord TB. the 04-05 TSX IM is what, 60mm, while the 06-07 TSX IM is 64mm?
I was just wondering because I've still got my 05 TSX IM from my old car haha.
Reply #212 on:
February 16, 2012, 12:37:59 AM »
If the bore of the IM is smaller than the bore of the TB, then you would need to get it machined. If you don't, you will lose power because of the turbulence created. Only other thing I could think of is the TB bolt pattern being different. I don't have one, so I don't know if they are the same or different.
SilverCM5
Reply #213 on:
March 27, 2012, 09:27:29 PM »
Good write up Tim! I seen this post on DriveAccord.net Keep up the good work Tim!
Reply #214 on:
March 28, 2012, 12:14:21 AM »
I can't take credit for the DIY. It was Skippy that originally posted this, I just copied it over here.
SilverCM5
Reply #215 on:
March 28, 2012, 12:19:28 AM »
Ok, my bad. Thanks Skippy! =D
Reply #216 on:
March 28, 2012, 12:23:31 AM »
Since he doesn't really come on the site that much any more, I'll let him know you appreciate it the next time I talk to him.
Reply #217 on:
May 14, 2012, 12:41:17 AM »
Sorry to bring this back to life...finally getting around to tackling mine sometime in the next few days.
Quick question - is there a gasket in between the intake manifold ("plenum") and the engine. I see it says to only pick up a throttle body gasket.
Reply #218 on:
May 14, 2012, 01:10:11 AM »
There is a metal gasket between the intake manifold and the injector base that's reusable.
Reply #219 on:
May 14, 2012, 01:19:54 AM »
Quote from: Jeff on May 14, 2012, 01:10:11 AM
Thanks to whoever put this in the right spot and thank you Jeff for the quick response.
Reply #220 on:
June 12, 2012, 04:28:21 PM »
Quick question - I was going to install the intake manifold but a buddy of mine suggested I look into the RBC manifold the TSX guys swap theirs out for. Would it fit?
Reply #221 on:
June 12, 2012, 04:35:21 PM »
It will fit, but you will lose power. That manifold is for higher revving motors. Your motor doesn't rev high enough to actually see those gains. You will lose power in the lower rpm range.
Reply #222 on:
June 12, 2012, 05:09:11 PM »
Quote from: timot_one on June 12, 2012, 04:35:21 PM
That explains it.
Gracias, Tim.
Reply #223 on:
June 12, 2012, 06:54:19 PM »
De nada Eric.
Reply #224 on:
June 25, 2012, 08:16:54 PM »
So I bout a TSX intake manifold recently. After getting it I could see that it was stored somewhere for a while and there is spiderwebs and other residue inside of it. How do I clean it properly?
Here's a pic
14
15
16
17
20
