September 27, 2026, 07:22:29 PM
Big Mouth for the 7th Gen V6
Topic: Big Mouth for the 7th Gen V6 (Read 17354 times)
August 09, 2009, 04:13:23 PM »
Well, as you guys know I have been building larger displacement ported out engines for our cars which have been providing nice numbers all the way up to 5500 RPM and then would just level out. With all the porting and displacement increases and cams the engines just don't seem to be able to get enough air to continue making power above 5500RPM bue to the restrictions at the throttle body, well I think I found a solution for people staying NA. How about a 80MM throttle body, yes that should flow enough, but one problem the damn DBW system, well I got a solution for that too.
This is going on WorldOn1Finger's J33 soon so we should have some new data soon to see what gains it makes, but butt dyno even on the stock J30A4 in my car says something is there. Alot of boring was done to the intake to open it up to 80MM as well and had to add (weld) to the neck in a couple spots where the metal was paper thin or even cut completely thru. Now that it has been tested and the cable conversion system is working properly and the ECU is happy with it I need to finish port matching the throttle body and send it off to Brett.
Next for this will be a upgrade for the 6th gen AV6/2nd gen CL-TL.
suleman_manji
Re: Big Mouth for the 7th Gen V6
August 09, 2009, 04:17:37 PM »
Damn that's HUGE!
lol there's still more metal to bore!
T
X
Squad #
flick
r
fb
[img]http:
August 09, 2009, 05:32:15 PM »
That's insainly huge.
August 09, 2009, 05:51:08 PM »
that's sexy
August 09, 2009, 07:54:01 PM »
That is quite large compared to stock.
Quote from: "NVA-AV6"
butt dyno even on the stock J30A4 in my car says something is there. \
I thought you were F/I.
August 09, 2009, 09:11:22 PM »
Awesome work Paul. More detail on the DBW to cable conversion. I hate the bad lag of the DBW. 80MM is freakishly huge. Will you able to do something for the CT Engineering SC?
August 09, 2009, 09:11:24 PM »
I un-fi'ed for this project
, but will have it back on latter this week.
August 10, 2009, 06:01:13 AM »
Thank you for continuing to create new innovations for our cars.
August 10, 2009, 06:53:00 AM »
You know, seeing an opening that big gives my a chub. Good work as usual Paul.
August 10, 2009, 02:27:44 PM »
Save that for the special thread, buttpirate, as for this addition to the J33, Paul, we may need to talk cost on this piece at a slightly later date. This may be worth-while for me
August 10, 2009, 02:35:25 PM »
Quote from: "05AccordV6"
You just wish I was talking about you. Don't be jealous. Let's keep this OT. Its too bad you don't put these skills to work on the K series Paul. Or maybe you do?
August 10, 2009, 05:43:08 PM »
Paul, I know this is really more of a high RPM Mod to keep the airflow coming in so the motor doesn't level off or even drop back in power above 5,500 RPM, but is there any additional benefits to this in the low-mid engine speeds? better Throttle response? An actual increase in HP or TQ?, or is this just a generally good support modification for use going bigger than 3.0 displacement?
August 10, 2009, 06:21:09 PM »
Well according to my butt dyno there definatly was better throttle response and a little something more on the low end with my stock J30A4.
August 10, 2009, 06:22:43 PM »
I can and do to a certain extent, but you K guys already have tons of AM support, it's us J guys that are pretty screwed.....
August 10, 2009, 09:46:39 PM »
have you figured out a cost for this, or even a rough ballpark?
