June 17, 2026, 05:21:54 AM
Author Topic: Quick, need an answer. Endlink issue  (Read 8116 times)
evo6011
evo6011 pfffft.
« on: August 06, 2009, 09:17:47 PM »
Anyone know if a honda stealership stocks a rear end link for a sedan? Long story short mine is broken and I need a new one asap and dont want to order one and wait a few days for it to get here.
Reputation Power: 25
« Reply #1 on: August 06, 2009, 09:19:27 PM »
Part stores do, advance, oreilly, etc.
evo6011
evo6011 pfffft.
« Reply #2 on: August 06, 2009, 09:50:10 PM »
really? i will have to check there after the stealer. all else fails i can order it and wait like 3 days for it to show up. stupid
$11 part.
« Reply #3 on: August 06, 2009, 09:52:45 PM »
I think they are a lot cheaper to. I think it is about 25 at a dealer. I think we are talking about the same part. We are if you are referring to the thing that attaches to the RSB.
unclejud49348
unclejud49348 pfffft.
« Reply #4 on: August 07, 2009, 12:31:35 AM »
Hey if you can find the part at an Advance Auto Parts store, here's a link to a thread here on ECM w/ a $10 off coupon off a $25 purchase.
viewtopic.php?f=52&t=1434
Just trying to help out :smile:
Justin - NHBP Sedan 5AT
(^^ Made by Milan, thanks!)
evo6011
evo6011 pfffft.
« Reply #5 on: August 07, 2009, 10:03:07 AM »
Quote from: "unclejud49348"
 Thanks man, I called them this morning and they said they have it in stock. So with the coupon, I should be able to get this part for around $15.
« Reply #6 on: August 07, 2009, 10:06:27 AM »
Quote from: "evo6011"
Nice. What are you waiting for then? Git r dun!
hondaguy214
hondaguy214 pfffft.
« Reply #7 on: August 07, 2009, 09:20:53 PM »
it takes 3 days for your dealer to get parts? at my toyota dealer if you call before 4 o clock. we order it that day its there in the morning waiting.
NECM SQUAD#6
« Reply #8 on: August 07, 2009, 09:23:35 PM »
It also depends on what warehouse supplies the dealer.
evo6011
evo6011 pfffft.
« Reply #9 on: August 07, 2009, 10:03:43 PM »
 I had to wait to get off work.
 *update* I have the part from advance auto in my garage right now and will install it in the morning. The part look very similiar but it does not have the spot where you put a hex wrench in to hold it in place while you tighten the bolt. Also, the part looks to be bare metal so I will splash on a little "camo" flat black before putting on the car.
« Reply #10 on: August 07, 2009, 10:07:54 PM »
That doesn't sound too bad. How is the bolt held then?
evo6011
evo6011 pfffft.
« Reply #11 on: August 07, 2009, 10:16:44 PM »
its just a standard 14mm nut, i suppose using a dab o loctite will hold it in place. if i'm
not mistaken, red is the color to use. also on the end link (i will post a picture tomorrow) the back portion has a bolt/grease fitting, where as the stock end link has a piece of plastic that has 4 blue dimples.
« Reply #12 on: August 07, 2009, 10:22:32 PM »
I meant the head of the bolt where on the stock one you would insert a hex wrench. How would you hold this one?
evo6011
evo6011 pfffft.
« Reply #13 on: August 07, 2009, 11:49:23 PM »
got it now, I'll get back with you on that .
rajin929
rajin929 pfffft.
« Reply #14 on: September 09, 2009, 01:13:55 PM »
I ordered a set of the Moog rear sway bar endlinks for the sedan, you hold the bolt with an open end wrench on the one side of the sway bar, then the bar, then the nut on the other side.
A little more $$ than the oem replacements but the Moog ones are more beefier and have the grease fittings.
1999 Acura 2.3CL - sold
