September 28, 2026, 02:15:41 PM
How To: Transmission Fluid Change
Topic: How To: Transmission Fluid Change (Read 56710 times)
Re: How To: Transmission Fluid Change
July 04, 2009, 11:54:09 AM »
How much does the i4 Tranny filter cost and can I use any transmission oil or does it have to be Honda Only?
July 04, 2009, 12:31:55 PM »
Not Sure about the filter, but you
MUST
use honda ATF.
July 04, 2009, 12:34:10 PM »
Quote from: "thisaznboi88"
what is the part number on the i4 tranny filter? I am planing to do an automatic tranny cooler and want to make the car feel as good as it can be.
25430-PLR-003
Around $15. Personally I would go with Honda only but I dont know if you have to.
July 04, 2009, 12:46:40 PM »
Thanks guys, I will us Honda Only and found the i4 AT filter
here
. Part #4 for $13.86
Found Honda Genuine AT Fluid
here
[/size] at $9.55 a bottle. Also found Honda Genuine PS Fluid
here
[/size]at $4.14 a bottle.
July 04, 2009, 10:49:35 PM »
thanks for the part number. I have 6 qts of the autotranny fluid for free since my uncle gave me some. He works at honda
July 04, 2009, 11:33:50 PM »
In my experience from ordering chemicals online your going to pay a shitload in shipping. When I changed my ATF it was just cheaper to buy the fluid at my dealer. Just something else to think about.
InFuMoUs
July 05, 2009, 06:07:09 PM »
Ya I don't think you save much by buying it online. Probably would end up costing the same amount when buying at the dealership.
Steve -
Squad/
Team Crazy Creashunz
July 06, 2009, 10:03:55 PM »
how many do you guys need? I have like 10 bottles and am more then willing to hook it up. I am probably going to use 3-4
Reply #23 on:
November 27, 2009, 10:06:30 AM »
Quote from: "NVA-AV6"
The yellow circle is the I4 filter.....
Any tips on removing and replacing the i4 filter there?
How do you go about removing it safely?
Reply #24 on:
December 01, 2009, 09:43:31 PM »
I was wondering... what is the size of the hose that connects to the i4 filter? I never really checked. I think I'm going to grab a Magnefine filter for when I do my tranny fluid. Need to get the Z1 too.
Reply #25 on:
December 02, 2009, 02:48:06 PM »
How much does the ATF z1 go for now? I have a few bottles that I can't use. I can hook you guys up if you want.
Reply #26 on:
December 02, 2009, 03:18:12 PM »
My local dealer wanted $9.15 a quart. I was just going to go on eBay and get a case of 12 to store in my house and do changes every 15k or so since I do a lot of city driving.
Reply #27 on:
December 02, 2009, 03:36:30 PM »
Hey Ken, how many quarts do you have? I'm going to be needing about 10 quarts to do my tranny fluid. Unless I should go with a fourth drain & refill, otherwise I'll be needing about 12-13. Send me a PM.
Edit: I just called my local Honda and they want $6.88 a quart, and $82.56 a case (12 quarts at normal price
), plus tax.
Reply #28 on:
January 26, 2010, 12:08:57 AM »
Sorry to bring this back up. I'm going to try to do this myself without a breaker bar and help from a family member. I see that it says to locate a fill plug. I know the 4 cyl sedan doesn't have one (mine doesn't) as I believe we fill from the dipstick hole. Why is the first line of the OP state its for a 4 cyl Sedan? Am I wrong?
Also, do I let it remove old fluid for about 5 mins then drop in 3 quarts straight from Honda? Then let it warm up and check the level? Another question. I bought a Magnefine filter, do I change that before I put in new fluid?
Reply #29 on:
January 26, 2010, 07:46:04 AM »
You shouldnt need a breaker bar or help from a family member, it is easier than an oil change. I am not sure if the sedan has one or not but I have a 4 cylinder sedan and used the dip stick hole to fill it with. I would let it drain for longer than 5 minutes if I were you. Some people do a series of changes, but it is up to you. As for the filter, I would think you could do it while the fluid was draining. Hope that helps. You dont even have to jack up the car. Make sure you have a long funnel. Hope this helps.
