September 23, 2026, 10:04:05 PM
Bolt Ons
Gen7 J30 Bolt On list
Topic: Gen7 J30 Bolt On list (Read 109806 times)
Re: Gen7 J30 Bolt On list
Reply #75 on:
August 14, 2012, 05:30:47 PM »
Paul, you're a genius.
Reply #76 on:
August 14, 2012, 06:38:14 PM »
Quote from: NVA-AV6 on August 14, 2012, 03:50:26 PM
Now if I can just figure out how to keep the ECU happy while disableing the DBW system....so I can pass emissions right
Reply #77 on:
August 14, 2012, 06:39:21 PM »
That looks kinda crazy. What size are those TB's?
Reply #78 on:
August 14, 2012, 06:49:12 PM »
65mm ,stock 2nd gen CL-S/TL-S and Pilot/Oddy
Last Edit: August 14, 2012, 06:51:02 PM by NVA-AV6
Reply #79 on:
August 14, 2012, 06:53:29 PM »
Is there any way to run dual DBW TB's?
Reply #80 on:
August 14, 2012, 07:11:07 PM »
Looking into it, but the controller can not run two servo systems.
Reply #81 on:
August 14, 2012, 07:18:52 PM »
That would be pretty cool. Would one servo be able to move both tb plates?
Reply #82 on:
August 14, 2012, 07:23:40 PM »
Possibly........
Reply #83 on:
August 14, 2012, 07:34:36 PM »
Reply #84 on:
August 14, 2012, 08:19:41 PM »
Now that's amazing >
Reply #85 on:
August 14, 2012, 08:38:46 PM »
....a rod going from on tb to the other (master and slave)? As long as the servor has enough power with the added friction and weight.
Reply #86 on:
August 14, 2012, 08:57:53 PM »
Yup, that is what I will be trying, there goes $400 in throttle bodies, $80 for a industrial 0 backlash shaft coupler, about $300 in raw aluminum and $200 in welding supplies, not to mention the hours to make another mani........
Reply #87 on:
August 14, 2012, 09:29:30 PM »
If only someone you know had access to a Solid Works workstation lol. I wish i had the time. It would save you, at a minimum, some material cost.
Re: Re: Gen7 J30 Bolt On list
Reply #88 on:
August 14, 2012, 11:34:38 PM »
Actually, I have brief knowledge in Solidworks. I could probably design some things given enough time to learn the program better. I have full access to the software on campus in the Engineering building. UCF ftw!
Silver Bullet
Reply #89 on:
August 15, 2012, 02:46:51 AM »
Someone told me about this. I would totally be interested in the TB. Perhaps that will help us make the ~300whp mark on our J30's?! Since a few guys on V6P are making 270ish WHP with no tune and don't have all bolt-ons...!
2006 AV6 6MT
