September 26, 2026, 02:22:28 PM
Author Topic: static noise  (Read 6242 times)
lilmalu
lilmalu pfffft.
« on: June 29, 2009, 11:01:09 AM »
So since installing my headunit 2 weeks ago, i've been pretty much having a good time with it. I had two problems with it:
1) My dad told me that when listening to the radio, it appears to be full of static, and that it tends to cut out in certain places, which never happened with the OEM one.
2) Not knowing if this is a Metra kit flaw or not, but you can literally push the top portion of the metra kit and the whole thing will fall in, thus making a huge gap between the OEM player and the metra kit.
Does anyone know a solution to this?
Reputation Power: 25
« Reply #1 on: June 29, 2009, 02:00:46 PM »
I'm guessing it is the lower cubby kit. If so, make sure that it is completely snapped in, I believe that it has two clips on the side, and that all the screws are in.
« Reply #2 on: June 29, 2009, 03:55:30 PM »
1. Probably a shitty AM/FM tuner in the h/u.
2. Metra kinda sucks, but which kit?  The upper or lower mount?
lilmalu
lilmalu pfffft.
« Reply #3 on: June 29, 2009, 04:34:58 PM »
Quote from: "wtcii"
I got the Metra lower mount kit. I'm thinking I should get the Honda Attachment Kit, which I'll get when I'm in the states in Aug. As for the head unit, I got the Alpine cda-9886.
« Reply #4 on: June 29, 2009, 04:55:51 PM »
Hmmmm.  Check how you have it mounted in the metra kit.  Did you use the ISO brackets or the cage?  Also, make sure your antenna connection is secure and there's no damage to the antenna cable.  I'm not one for the radio, so I never use mine.
lilmalu
lilmalu pfffft.
« Reply #5 on: June 29, 2009, 07:02:02 PM »
I used the ISO bracket that came with the kit. But after pulling it apart, I didn't see the two clips that should clip like the cubby did. So i'll probably get the honda kit and see if that helps. as for the radio, i spoke with some guy at futureshop (bestbuy) and they said it could probably be that the antenna isn't being "amplified and noise suppressed" enough. made me laugh for a second
« Reply #6 on: June 29, 2009, 07:20:13 PM »
There should be no problem with the metra kit. I have the lower cubby kit and it is perfect. Also, I thought the Honda Audio attachment was for only DD
« Reply #7 on: June 29, 2009, 07:36:08 PM »
I'm not sure if the Honda kit will work for this.  Hopefully it will, but you never know until you try.
Asim pfffft.
« Reply #8 on: June 29, 2009, 08:38:54 PM »
Whats the part no#?
I've looked for this for awhile
