September 25, 2026, 10:19:02 AM
Author Topic: AXIS ELITES!!!  (Read 5790 times)
LvaC03NyC
LvaC03NyC pfffft.
« on: May 22, 2009, 09:45:51 PM »
http://www.axiswheels.com/wheels.php?id=elite
These rims in my opinion would look so good the only problem is that their 420.00 a piece :cry: . Anyone know of any sites or shops around the nyc area with some sort of a deal.
« Reply #1 on: May 22, 2009, 11:17:22 PM »
You think you're going to fit a set of 19x9.5 wheels without modifying your fenders and wheel wells?  Their site doesn't even show the offset either.  You may want to make sure that they'll fit before you throw down over $1700 for a set of wheels.
Reputation Power: 25
« Reply #2 on: May 22, 2009, 11:19:29 PM »
I dont like them, but to each his own.
LvaC03NyC
LvaC03NyC pfffft.
« Reply #3 on: May 23, 2009, 09:52:00 AM »
# Diameter: 19"
# Width: 8.0"
# Bolt Pattern: 5 x 114.3
# Offset: +45
# Color: Matt black center with machine accents
# Tires: Falken FK 452
# Size: 245/35/19
I found these specs on the rims....What would I have to do to make these work??
« Reply #4 on: May 23, 2009, 10:16:56 AM »
This might give you an idea, Go Here:
http://www.rims-n-tires.com/rt_specs.jsp
LvaC03NyC
LvaC03NyC pfffft.
« Reply #5 on: May 23, 2009, 10:47:40 AM »
Great Site....Put in the numbers and came up with this
Suspension   Package is 10 mm (0.4'') closer to suspension/brakes components. Acceptable for most cars.
Fenders   Package will stick out 30 mm (1.2'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
Wheelwells   Will fill out the wheelwell by extra 25 mm. Make sure that you have enough room under the fender. If not, consider lower profiles or smaller rims.
