September 25, 2026, 07:38:21 AM
Pages: « First < Previous 1 ... 18 19 [20] 21 22 Next > Last »   Go Down
Author Topic: The Only Exhaust Thread You Should Ever Post In  (Read 200457 times)
Icebox pfffft.
« Reply #285 on: November 26, 2012, 12:53:11 PM »
custom.
« Reply #286 on: November 26, 2012, 01:45:17 PM »
Like David said, custom is the only option.  Actually, there are no options for sedans.
« Reply #287 on: November 26, 2012, 03:45:13 PM »
Truth. You could look at the v6 options though but you would still need to customize it a bit.
Arielit0oo pfffft.
« Reply #288 on: November 26, 2012, 06:19:20 PM »
Asim pfffft.
« Reply #289 on: November 27, 2012, 10:24:10 AM »
Custom blast!
I think a TSX or Coupe i4 option would be better than the V6 option as long as they're extended
« Reply #290 on: November 27, 2012, 12:07:09 PM »
TSX isn't a bad alternative.  Some of them are usually more expensive than custom though.
Icebox pfffft.
« Reply #291 on: November 27, 2012, 02:51:58 PM »
my personal recomendation in to pick up a couple maganflow mufflers of the internet and take them in to a local exhaust shop and have them weld them up with some bigger diameter ss piping.
« Reply #292 on: November 27, 2012, 03:44:27 PM »
That's a much better option actually. Just make sure the shop does quality work and uses good material. I've been through a few exhaust shops and a lot of them hack shit.
fatbastard
fatbastard pfffft.
« Reply #293 on: February 06, 2013, 08:12:12 PM »
i chucked out the stock catback for a cusotm 2.5" exhaust and the primary A/F sensor conked out. coincidence?
-- Charles --
2005 Honda Accord 2.4L sedan
2011 Subaru STi sedan
« Reply #294 on: February 06, 2013, 08:17:53 PM »
Not really. How many miles are on the A/F sensor?
fatbastard
fatbastard pfffft.
« Reply #295 on: February 06, 2013, 08:22:42 PM »
33,000km or about 20,000miles.
-- Charles --
« Reply #296 on: February 06, 2013, 11:17:29 PM »
That's pretty low for a sensor to crap out.  Did you check the wiring for damage?
fatbastard
fatbastard pfffft.
« Reply #297 on: February 07, 2013, 01:23:30 AM »
the plastic coating seems to have rubbed out exposing some wires.
i got a P0134 code (AF sensor heater malfunction). replaced the sensor with a new Bosch and now it's all good.  Smiley
-- Charles --
« Reply #298 on: February 07, 2013, 09:32:47 AM »
Yeah, damaged wires makes sense then.  Make sure the wire harness is secured so that doesn't happen again.  I believe there is an issue with using Bosch sensors on Hondas.  That may cause you problems down the road.  If you can, try to use Denso sensors.
« Reply #299 on: February 07, 2013, 10:45:57 AM »
That depends Tim. On which Honduhs are we talking about?
My Bosch has been running like a champ for about 3 years and roughly 40k miles. It was conveniently sold at a local parts store.
Pages: « First < Previous 1 ... 18 19 [20] 21 22 Next > Last »   Go Up
