September 29, 2026, 10:07:23 AM
Ignition switch help.
Topic: Ignition switch help. (Read 12241 times)
seiplentz
May 14, 2016, 05:41:18 PM »
So my ignition switch is acting up. Ill turn the key and I hear a slight electrical noise coming from it and the car doesn't start. Wiggle the key a little and it starts. I found a replacement one on rock auto. I don't have an issue with changing it myself but the question I have is about the keys. It looks like it comes with new keys? But they don't have the keypad on them. I'm guessing I will need to get the door rekeyed and can I program new keypads or keys myself? I'm debating on just dropping it at the dealer for this repair then not deal with it.
Re: Ignition switch help.
May 14, 2016, 06:42:49 PM »
They will need to be programmed at the dealer unless you have access to a programing device i.e. Fly100 etc. As for the door, I think you're correct. You'll need to get it rekeyed. I hate to say this but I would get a quote from the dealer to fix the ignition first. It may save you some hassle.
