November 07, 2026, 06:27:22 PM
Author Topic: Pascal's 5AT -> 6MT conversion, parts list and more.  (Read 15349 times)
Pascal
Pascal pfffft.
« on: March 30, 2015, 09:18:31 PM »
I decided to start a new thread about my future conversion, this will also act as my parts list checkup to make sure I have everything and if there is something I should replace.
It should be a bit different than the current thread, since there is no pictures and official part list.
I'll update everything in this post to make everything clear.
This will be done on a 2003 accord sedan automatic, with a K24A2 swap.
The parts will be divided to match honda's parts list catalogue
The list will have this form:
"part number " / "description" - "the vehicule it came from or the vehicule it was meant for" (" if I got comments or used an aftermarket part ")
Some parts are meant for more than one model, just check the application list of the part number.
_________________________
Parts I have so far :
CLUTCH - TORQUE CONVERTER
- 22100-RBB-005 / FLYWHEEL - 2004 TSX MT  (might not use this)
- 90011-PNA-B00 / BOLT (12MM) - 2004 TSX MT (AT bolts are not the same)
- 22200-RBB-005 / DISK, FRICTION - 2004 TSX MT (will be replaced)
- 22300-RBB-005 / DISK, PRESSURE - 2004 TSX MT (will be replaced)
- 90034-689-000 / BOLT, TWELVE POINT (8MM) (TOKAI TRW) - 2004 TSX manual (got to check again if I have them)
CLUTCH MASTER CYLINDER
- 46920-S7A-A03 / MASTER CYLINDER ASSY., CLUTCH - 2003 Accord Sedan MT
- 46971-SDA-A01 / TUBE, CLUTCH FLUID - 2003 Accord Sedan MT
- 46965-S6A-013 / TANK ASSY., CLUTCH FLUID - 2003 Accord Sedan MT
- 46966-SDA-A02 / HOLDER, TANK - 2003 Accord Sedan MT
- 46930-S7C-E02 / CYLINDER ASSY., CLUTCH SLAVE - 2004 TSX MT
DRIVESHAFT
- 44500-SDA-A00 / SHAFT ASSY., HALF - 2004 TSX MT
ELSE
- 2004 TSX 6 speed manual transmission.
- Ktuner 2005 k24 accord auto ECU
- 2004 TSX 6 speed CV shafts
- 2003 Accord k24 sedan shifter box
- 2004 TSX shift linkage cables
- 2005 Accord v6 manual clutch pedal, brake pedal and misc. parts.
- 2003 Accord sedan k24 shifter boot
- Beer, a lot of beer  Cheesy
Parts I still need :
- 22100-RBB-005 / FLYWHEEL - 2004 TSX MT (Might buy a used 2006-2011 civic si FW local for 40$, seems to be very similar to the RSX-S)
- 22200-RBB-005 / DISK, FRICTION - 2004 TSX MT (with clutch kit, considering exedy stage 1)
- 22300-RBB-005 / DISK, PRESSURE - 2004 TSX MT (with clutch kit, considering exedy stage 1)
- 22103-PNA-003 / BUSH (21X24X8) -  2004 TSX MT (with clutch kit, considering exedy stage 1)
- KTD-CLK-RHD / STAINLESS STEEL CLUTCH LINE KIT (RHD) - K-swapped cars (From ktuned, RHD version because it is slightly longer)
- 46928-S5A-A01 / SEAL, MASTER CYLINDER - 2003 Accord sedan MT (included when a new CMC is bought)
- 46911-S70-003 / PIN, LOCK (8MM) - 2003 Accord sedan MT
- 46912-S84-A00 / PIN, CLUTCH PEDAL - 2003 Accord sedan MT
ELSE
- Manual cluster (dammit they all got different part numbers, found a DX sedan one for 30$ but not sure if they got less "features" than me. Also know a guy that has his crashed EX-L sedan manual cluster hanged in his garage, he might consider selling it)
Please comment if you think I forgot something.
Suggestions are welcome too !
« Last Edit: April 02, 2015, 10:57:22 PM by Pascal » Logged
wawade86
wawade86 pfffft.
« Reply #1 on: May 11, 2015, 12:12:25 AM »
subbin to this shit for sure. my post in K20a.org has no replys yet as well Flippa!
I will only change when the pain of staying the same become greater than the pain of change.
wawade86
wawade86 pfffft.
« Reply #2 on: May 12, 2015, 01:12:01 AM »
According to other Honda AT to MT posts we will need a manual starter and transmission mounts. Parts numbers differ from the MT to AT.
« Last Edit: May 12, 2015, 01:39:45 AM by wawade86 » Logged
Pascal
Pascal pfffft.
« Reply #3 on: May 12, 2015, 07:08:18 AM »
You are right for the mounts, but wrong for the starter
bian.yy
bian.yy pfffft.
« Reply #4 on: August 31, 2015, 12:36:04 AM »
Hi Pascal
I got an CM5 with K24A8 and DCLA 5AT in China market, I'm quite confident on the mechanical parts swap with a 5MT or 6MT. But there are some ECM issue what I'm still not clear, could you share your information to help me?
a. Pin9 of D connector on ECM, which is nameded CRMTCLS, is supposed to acquire clutch pedal switch for cruise control, if I swap then how can I deal this pin.
b. How do I get speed sensor signal from the tranny? I read the diagram,it seems on AT, ECM read VSSOUT and then provide speed data to gauge cluster via CAN bus?
c. How to deal the P signal on shifter which prevent car key from remove, I think I can force this wire to "ENABLE"
d. I belive the D indicator will flash after swap, how to do?
e. If 6MT, is there a position on chassis to install that reverse lock solenoid?
f. VSA module will control engine RPM and tranny, if I still want VSA, do I need a MT ECM to replace?
These are what I worked out for now, I'm not sure if there are more issues soon. I haven't buy any parts for the moment, just work on manuals and diagram to check the feasibility.
Cheers!
