October 27, 2026, 05:02:40 PM
Bolt Ons
p2r spacer and gasket
Topic: p2r spacer and gasket (Read 37790 times)
accordmatt
Accord Lover
February 26, 2015, 09:58:38 PM »
well I received my p2r mid section gasket for my tsx im swap today. along with spacer an tb gasket. but ive got a problem spacer and tb gasket is not gonna fit or work. im not sure if its the wrong ones or what. it says on package for 06 accord and tsx. but obviously its not gonna work any advice that I don't know of before I send this back?
gasket and spacer are just like this
96 Accord Ex H22 swap fully modded - under cont.
90 Crx B16a Hondata ecu fully modded 11 1/4 mile - sold
95 Eagle Talon Tsi AWD modded 9 1/4 mile - Sold
00 Accord Ex I,H,E - totaled
06 Accord Exl - Currently modding
Re: p2r spacer and gasket
February 27, 2015, 09:42:37 AM »
I'm sure you tried rotating the spacer 90°. What year is your Accord?
Honestly, I would send the spacer back. The bore of the spacer being larger than the inlet of the manifold will create turbulence and you will lose power. You would need to port it out and blend it so it has a smooth transition. I don't put much stock in TB spacers doing much of anything. I guarantee that if the bolt holes lined up on that, you would lose power.
Pascal
February 27, 2015, 12:33:04 PM »
^what he said
accordmatt
Accord Lover
March 02, 2015, 07:19:48 AM »
Yea sorry I've been busy moving. But spoke with p2r n sent them pics. The parts were for correct car not sure why they don't match. But they are sending me the ones to fit correctly. So as soon as I get them yes I will be port matching
March 02, 2015, 10:33:20 AM »
Good call. Port matching will be necessary.
accordmatt
Accord Lover
March 04, 2015, 02:44:06 PM »
definitely port matching that would be stupid not too. im trying to increase tq/hp by not port matching would probally drag me down to less than I had before. so now I am just waiting for p2r to send out the new spacer and gasket
accordmatt
Accord Lover
March 20, 2015, 10:50:39 PM »
no I actually have the order from online and the one they sent me. I ordered for 06 accord with dbw. but they fixed it and mailed me correct one within a day along with 2 tb gaskets, sent a extra for both sides of spacer. so now it fits perfect and will be even be better after I finish the port and polish
March 20, 2015, 11:51:29 PM »
nice
accordmatt
Accord Lover
March 21, 2015, 10:42:39 AM »
[/URL
so I porting tb n polishing mid ports and as much as I can get down inside. I don't have a flexible extension to go all the way in. but if I ever find one or run across someone with one then I will. as far as matching the mid ports I think im gonna go hold off till a later date, cuz if I do one side I gotta do the other and I don't wanna have to take injector base off when im going in. the mid section gasket is just a tad larger. so with me polishing as much as I can and port matching tb I think it will be enough for now. then when I get some head work things done and go back in then I will get it all done.
accordmatt
Accord Lover
March 21, 2015, 10:44:31 AM »
by the way I am not done im not leaving it as it and putting on I still have a good bit left on im to finish before then. will post update pics
March 21, 2015, 07:48:26 PM »
are you sure your tb will fit? i could have swore that the 06-07 has a different bolt pattern
accordmatt
Accord Lover
March 22, 2015, 12:46:39 PM »
I have a 06 tsx im and the 06 tb m spacer so I don't see how it wont bolt up
March 22, 2015, 04:32:15 PM »
accordmatt
Accord Lover
March 23, 2015, 03:48:44 PM »
my accord is a 06
March 23, 2015, 03:51:32 PM »
u 100% sure?
I swear the 06-07 looks like the one on the left and the 03-05 is the right
