August 25, 2026, 01:17:40 PM
Author Topic: My friend's J35A8 TSX  (Read 9692 times)
Pascal
Pascal pfffft.
« on: February 11, 2015, 12:02:11 PM »
Few picture of my friend's project, J35A8 from a RL into his 2004 TSX. This is my engine's donor car and he is the guy that swapped my car too.
Every parts are oem parts, there was no fabrication needed (except exhaust, fans, coolant overflow and other minor stuff)
« Reply #1 on: February 11, 2015, 01:17:23 PM »
I seem to recall a guy that first did that swap into a tsx on k20. I wanna say it was Bardi but I may be way off.
« Reply #2 on: February 11, 2015, 01:47:02 PM »
It was Eric Brockway that did it on k20a. I was fortunate enough to see a lot of the progress. I believe he is working on a J37 set up now.
Sweet swap though. Glad to see he got everything going. I'm guessing he used a TL sub frame.
Pascal
Pascal pfffft.
« Reply #3 on: February 11, 2015, 04:35:12 PM »
You are right about the swap on k20a, but all the pictures were gone. He had to guess along the way, it is indeed an aluminum TL subframe.
« Reply #4 on: February 11, 2015, 07:30:58 PM »
Yeah. Eric took the pictures down. I know he had his TL sub frame modified to move the lower mounts inward so he didn't have a ton of camber in front.
Pascal
Pascal pfffft.
« Reply #5 on: February 11, 2015, 08:04:51 PM »
I don't know every part combination he used, but i know he didn't cut anything. He is using tls knuckles, upper arm, rotors and calipers too. maybe this fixes the camber issue, i'm not an expert haha
