November 06, 2026, 05:17:01 PM
Hyrdo lock motor build
Topic: Hyrdo lock motor build (Read 12639 times)
lilb52x
September 27, 2014, 02:01:58 PM »
Hello everyone i recently learned that my k24a4 in my accord has a blown head gasket due to tensioner bolts
broke and water pump not running causing motor to over heat.
Last week my wife's Tsx hydrolocked and she said it was a loud boom then shut off, I assumed it snapped a rod
the way she described it then i bought another k24a2 motor.
I got it towed to my work and pulled out the motor and found just a bent rod, the cylinder walls are ok and everything looks fine.
Now i'm thinking of building this motor and putting it in my accord, I want to put new rods of course, pistons
and cams and tuning of course. I will be using it as a daily driver i have been seeing some build ideas from k20.org and tsx club but i always found better info on here just want to see what you guys think thanks in advance!!
Re: Hyrdo lock motor build
September 27, 2014, 06:28:03 PM »
Sounds like a great idea. You can build a great motor with OEM parts. Have the block checked by a machine shop to be sure the cylinder walls aren't damaged, then get a fresh hone and go to town. Let me know of there anything I can do to help.
Pascal
September 27, 2014, 06:55:26 PM »
You can use Ktuner to run the tsx engine in your accord and it's quite cheap. If the engine is still good, could be a nice build !
September 27, 2014, 07:49:58 PM »
K Tuner is a great option, considering that nobody really makes KPro harnesses and the set up I have is one off.
lilb52x
September 27, 2014, 08:22:56 PM »
Yes I am getting ready to send it to a machine shop, and I already have ktuner just was looking for good opinions to build a nice daily with better rods pistons and possible some dic cams nothing too crazy just a fun daily.
September 27, 2014, 09:31:05 PM »
Have the machine shop check it first. New TSX rods and maybe 09 TSX or Si pistons would be good for an OEM bottom end.
