August 06, 2026, 01:52:24 AM
Problem 5 M/T
Topic: Problem 5 M/T (Read 8976 times)
tandyutama
Problem 5 M/T
September 14, 2014, 08:20:50 AM »
I write this based on my condition, don't know if there also same issue with me in this forum.
I can not directly shift my car when my accord engine started (when engine cold, usually in the morning) And after waiting idle for about 5 minutes, the shifter normal again.
This issue happened 2 days ago.
This morning, i realized that my clutch master has run out of oil, have filled. But the problem still.
Re: Problem 5 M/T
September 14, 2014, 01:44:18 PM »
You should bleed your clutch master cylinder first and see if that helps.
Re: Problem 5 M/T
September 14, 2014, 09:36:00 PM »
Also check to see how the fluid got low in the first place. May have a leak somewhere.
tandyutama
Re: Problem 5 M/T
September 16, 2014, 11:18:38 AM »
Quote from: Rich01 on September 14, 2014, 09:36:00 PM
Yeah, checked. There's leak on my clutch master, just a little, buy caused very uncomfortable shifting.
I brought my car to get it repair, and problem solved.
Thanks all for your replies.
