March 04, 2026, 01:33:15 AM
TL Auto Transmission Issue
Topic: TL Auto Transmission Issue (Read 15953 times)
August 08, 2014, 09:25:29 AM »
Trans has been shifting fine with zero issues, was originally changed at around 40k and then 80k. But after I changed it is when it started showing issues.
On the highway doing 75 today, I press the go pedal, about half way to the floor, doesn’t down shift, press a little more, then it jerks hard and down shifts. Seems like maybe a torque converter problem, maybe i didnt get all the old fluid out of the TC? I'm thinking I need to change the fluid again and make sure the shitty fluid is out. The old fluid color was fine, a little brown but not bad at all. I don’t know, but I'm pissed.
Re: Re: TL Auto Transmission Issue
August 08, 2014, 08:11:43 PM »
Sounds like the dreaded Honda v6 trans issue is rearing it's ugly head.
August 11, 2014, 09:53:55 PM »
Did you use Honda ATF DW1? Also, the trans fluid is due every 30k. Another note is to replace the filter. No one ever replaces, and even Honda/Acura doesn't recommend it. Its an easy fix on the V6 trans. Maybe try changing the fluid and filter. Remember you need to do the trans drain and refill 3 times. This way it cycles all the old fluid out and new fluid in. Make sure after refilling the fluid that you go through each gear with about 5 seconds intervals. Mainly P R N D. 1st and 2nd aren't necessary.
This may or may not remedy the problem, but it doesn't hurt to try. As Z said, 90% of Honda V6 auto trans do not last long.
August 12, 2014, 04:15:51 PM »
It hasn't done it again. Yes I did the 3x3 as they say. Now I'm worried when but not if, it's going to go.
