November 05, 2026, 08:09:13 PM
Author Topic: TCS light stays on after braking  (Read 21065 times)
« on: April 18, 2014, 04:56:49 PM »
I thought this was covered before but after searching I didn't find anything directly related to it. Here's what started happening, I backed into my driveway and noticed that non of my brake lights were on. I then noticed that the TCS light had came on.  While still holding the brake for about 10 seconds the brake lights finally came on. I turned the car off then back on to reset the TCS light.  I tested it again and  same thing happened.  I did a couple quick search and found that the brake light switch is the most likely culprit. A $7 replacement and a few minutes to fix.
Note: if the brake lights work fine with the TCS on, this may not be as easy of a fix and could most likely be the ABS control module (about $1k). I would try replacing the switch first though.
« Last Edit: April 18, 2014, 05:00:02 PM by Rich01 » Logged
« Reply #1 on: April 18, 2014, 10:29:31 PM »
I've had to replace the switch. Its easy give that a try. I believe with the switch unplugged your lights should be on. That might be an easy test.
« Reply #2 on: April 19, 2014, 03:03:48 PM »
When you replace the brake light switch, sometimes you need it to be reprogrammed to get that TCS to stay off. I had the same issue, and Honda charged me $50 to reprogram it. Those Rat Bastards.
« Reply #3 on: April 19, 2014, 09:14:01 PM »
ah, that's what I did Mike lol, read my post again. Good point about testing the switch tho.
Glad i didn't need to have that done. About how long ago was that? The guy in the parts department did mention that the one I got replaced a previous version. He had to double check to make sure it'll work with the 6spd. The old one was black and white and the new is blue and black.
« Reply #4 on: April 20, 2014, 12:08:44 AM »
My new one was blue and black a year or so ago
« Reply #5 on: April 21, 2014, 12:31:10 PM »
This was like back in 2006. Lol.
« Reply #6 on: April 21, 2014, 10:06:52 PM »
Lol yeah things might have changed since then. Maybe only the old switches needed to be reprogrammed? Idk.
