March 04, 2026, 01:32:21 AM
Motor Mount
Topic: Motor Mount (Read 18359 times)
super425
Motor Mount
June 11, 2013, 10:51:34 AM »
So I am looking into replace my motor mount. I want to see anyone have any suggestion for the mount from oem to poly mount. And I want to know where can I get the whole set front, rear, side, and other small mount.
Re: Motor Mount
June 11, 2013, 12:23:08 PM »
I have Innovative mounts. You probably don't want anything stiffer than the 60a bushings for a stock motor. I have 75a in mine because the 85a's made my car shake like a massage chair.
super425
Re: Motor Mount
June 11, 2013, 07:19:30 PM »
but the innovative mount is for v6 though. Is it interchangeable.
Re: Re: Motor Mount
June 11, 2013, 07:20:50 PM »
They offer them for 4 cyl and 6 cyl.
super425
Re: Motor Mount
June 11, 2013, 07:22:37 PM »
Can you give me the link cause I look into the website and it only available for v6
super425
Re: Motor Mount
June 11, 2013, 07:48:14 PM »
http://www.innovativemounts.com/ProductDetails.asp?ProductCode=10751
Is this the one you guys talk about
Re: Motor Mount
June 11, 2013, 07:55:48 PM »
They are the same mounts they use for the TSX. I got mine from Heel Toe.
super425
Re: Motor Mount
June 12, 2013, 10:59:46 AM »
thanks just order mine from heel toe.
super425
Re: Motor Mount
June 24, 2013, 10:07:42 PM »
Alright I got my mount, try to install the side one but it not line up. Is your line up just like that or did you change little thing.
Re: Motor Mount
June 25, 2013, 09:08:24 AM »
Not sure I understand the question. Do you have a picture?
super425
Re: Motor Mount
June 25, 2013, 12:34:39 PM »
My question is the side mount is not fit. If i line up the top 2 bolts, the bottom 2 is not in correct place.
Re: Motor Mount
June 25, 2013, 04:59:44 PM »
Yeah. I ran into that too. I just elongated the bolt holes for the part of the mount that bolts to the chassis.
super425
Re: Motor Mount
June 25, 2013, 06:26:56 PM »
Yeah but I think i cant do that cause it way off the line so i emailed Innovative already. And how is the vibration you have. Man my was so much specially sitting at idle with fan on. I want to see what other people review on this as i am consider going back to oem hydraulic mount
Re: Motor Mount
June 26, 2013, 12:40:18 AM »
What stiffness bushings did you get? I have 75a, and there's still some vibrations. Of course, you can't expect to get polyurethane mounts and no vibration. I expect it, but I also am one of the few people on here that makes the kind of power that justifies stiffer mounts. For the people that have basic bolt ons, OEM Honda mounts are just fine if you expect to have comfort.
super425
Re: Motor Mount
June 26, 2013, 01:22:39 AM »
I got 60a and at idle my whole dash shake like crazy. When I stop or the car drop to 5mph man that thing shake like no tomorrow.
