October 07, 2025, 07:27:06 AM
Need help with a stuck valve cover nut
Topic: Need help with a stuck valve cover nut (Read 8389 times)
May 26, 2013, 06:51:45 PM »
I'm having trouble getting this one nut off that's circled in the pic below. I can turn it both ways, but it just keeps spinning, so I assume it's been threaded. I need it off as I have to remove all of the engine valve cover nuts for a minor upgrade, and this one nut is holding me back. Any ideas how to get it off without some major surgery or cutting?
--Dave--
NECM Squad
Profile & Mods List
2003 I4 Accord Sedan
Re: Need help with a stuck valve cover nut
May 26, 2013, 08:20:20 PM »
Dave, that is the bolt for cam cap #1. It's probably just loose. Remove the other nuts from the valve cover and continue to loosen that bolt/nut and it will come out of the thread. Then you can hold it still from inside the valve cover and remove the nut.
May 27, 2013, 09:25:35 PM »
^ What he said, LOL.
May 28, 2013, 10:38:22 PM »
I actually don't follow your instructions Tim. I know I'm slow on the uptake, but I just can't picture what you're saying. I also don't actually need to get the valve cover off... I just need these 5-6 nuts off for a lil TLC, then back on they go. I just think I messed that one up years ago when I installed the red valve cover... don't remember how, but I did.
--Dave--
NECM Squad
Profile & Mods List
Re: Re: Need help with a stuck valve cover nut
May 28, 2013, 10:45:49 PM »
He's saying to remove the valve cover then grip that stud from underneath so that you can remove the nut. Replace the stud once you do.
June 04, 2013, 06:40:03 PM »
Dave just be careful as the stud is delicate and might snap if applying too much pressure. I had one snap on me! That nut is just holding the valve cover down. Once you get it off you will see that the stud is left there but you are able to take the stud out as well. So what Tim is saying is to loosen the other nuts with hopes that you will be able to get the nut and stud out together on that side. Which you will then be able to get a better grip on the stud to remove the nut!
Hopefully that clears it up for ya!
June 06, 2013, 11:21:53 PM »
Yeh, a little bit. I actually ordered some dress up pieces that replace all of the nuts and all of the studs too as it's all flush-mount. I've taken the valve cover off before (to remove stock for the red one). I'm hoping the gasket will be okay and reusable, but I also remember having to reseal the valve cover with some grey sealant in a few spots. Do I really need to use that shit again if I remove the valve cover? I made a damn mess with it last time. :
--Dave--
NECM Squad
Profile & Mods List
June 06, 2013, 11:30:06 PM »
Yes, unless you want oil leaking everywhere. Put the grey silicone around the corners where the head has a crease in it.
