August 06, 2026, 10:08:55 PM
Audio Systems
No light on OEM deck
Topic: No light on OEM deck (Read 6780 times)
super425
January 28, 2013, 08:59:54 PM »
so I just install a pioneer deck today but turn out the OEM deck Dont light up those button. Anyone know how to fix it or something. Thanks
Re: No light on OEM deck
January 28, 2013, 11:44:44 PM »
Can you clarify your exact problem? If I had to guess, your issue is with the illumination of the buttons on your new Pioneer deck not working?
If that is the case, then your problem is either a wire that needs to be connected for a defective head unit. Did you connect the illumination wire correctly?
January 29, 2013, 01:55:46 AM »
super425
January 29, 2013, 01:27:37 PM »
The problem i have is that OEM HU has no illumination after i install the pioneer deck.
January 29, 2013, 02:05:30 PM »
So, no backlight for the buttons and the screen when you turn your parking lights / headlights on?
The illumination wire does now go through the HVAC harness. It goes through the OEM audio system harness. If that is not connected, it's probably what's causing your problem.
Did you use the dual harness when you installed the Pioneer h/u? Did you make sure the illumination wire still goes to the OEM h/u connector if you used the dual harness?
January 29, 2013, 02:10:10 PM »
Quote from: super425 on January 29, 2013, 01:27:37 PM
Tim would probably be able to help you more, since I forget what the wire harness looks like for the gen 7 specifically. I think it is a normal harness, which pretty much disables the OEM head unit; since that harness includes the illumination wire, the OEM head unit no longer has a wire to connect to for that function.
You may, if one does not already exist, have to make a custom harness. When I had my gen 7, I wanted to keep navi and certain stock radio functions when I added my aftermarket stuff, so I made a custom harness.
edit: Tim beat my response..
