November 07, 2026, 06:27:41 PM
Pages: « First < Previous 1 ... 17 18 [19] 20 21 ... 43 Next > Last »   Go Down
Author Topic: Audio/Video Q&A Thread  (Read 410575 times)
NytShade
NytShade pfffft.
« Reply #270 on: December 19, 2010, 06:57:35 PM »
So everything is plug and play? On my old GMC (01 Sierra) we had the plug that went from the sony H/U and cut out the stock cd player harness, and then wired the Sony Plug wires to the stock wires color by color (with the help of a 12v forum) If that makes sense..
I will need the Metra Dual to single climate control plug?
http://www.metraonline.com/part/70-7864-DZ
What about the steering wheel controls? is that wired through the stock harness?
http://www.metraonline.com/part/ASWC
« Reply #271 on: December 19, 2010, 11:44:33 PM »
Do you have dual climate control right now?  If you do, you will need the dual to single climate plug.  If you want the steering wheel controls, you will need that other thing, and that will wire into your OEM harness most likely with the Metra adapter.
NytShade
NytShade pfffft.
« Reply #272 on: December 20, 2010, 08:30:28 PM »
Damn, this shits pricey yo.
« Reply #273 on: December 20, 2010, 08:50:53 PM »
Yeah, it adds up when you want stuff that's good.
« Reply #274 on: December 21, 2010, 10:04:57 AM »
Like they say, gotta pay to play.
unclejud49348
unclejud49348 pfffft.
« Reply #275 on: January 09, 2011, 08:43:06 PM »
Question for you Tim..
One of the wires that runs into my amp only accepts a small wire, and the wire coming to it is a much larger wire. Originally it was taped with electrical tape putting the two together, but now that doesn't work anymore and I have no power coming to my amp. What can I do to remedy this?
Thanks in advance..
Justin - NHBP Sedan 5AT
(^^ Made by Milan, thanks!)
« Reply #276 on: January 09, 2011, 09:24:45 PM »
I'll need to get more specifics Justin.  I'm not sure which wire you're talking about.  If you had two wires spliced together and just held together with electrical tape, then that's your problem.  Fix the install and it should work properly.  Don't ever go back to the installer that did the hack job that's in your car.
unclejud49348
« Reply #277 on: January 09, 2011, 09:35:39 PM »
I'll post a couple pics tomorrow to show what I'm talking about. Hard to explain without having it right in front of me.
« Reply #278 on: January 09, 2011, 11:13:45 PM »
I'm sure I could fix it if I was close by.  Too bad I'm not going to be in MI for a few more weeks.
status
GOMD
status pfffft.
« Reply #279 on: February 01, 2011, 02:42:46 AM »
does the oem 6 cd hu just plug and play with a single cd hu  both 2005 models?
-Alec
« Reply #280 on: February 01, 2011, 03:24:01 AM »
Not sure. If both are single zone climate, I believe its a straight swap. Same should go for dual climate.
« Reply #281 on: February 01, 2011, 03:10:15 PM »
It should just be plug and play.  The 6 CD may require a code, so make sure you have that.
status
GOMD
status pfffft.
« Reply #282 on: February 01, 2011, 07:00:54 PM »
gracis senors
-Alec
« Reply #283 on: February 02, 2011, 02:42:35 PM »
gracis senors
Gracias Señores
status
GOMD
status pfffft.
« Reply #284 on: February 05, 2011, 07:06:34 PM »
George Lopez?
i jingled the wires and plugs on the radio and hasnt done it in a while being an hour.... knock on wood
-Alec
Pages: « First < Previous 1 ... 17 18 [19] 20 21 ... 43 Next > Last »   Go Up
