November 08, 2026, 07:09:39 PM
Audio Systems
Audio/Video Q&A Thread
15
16
17
18
43
Topic: Audio/Video Q&A Thread (Read 410727 times)
Re: Audio/Video Q&A Thread
Reply #225 on:
May 20, 2010, 11:19:19 PM »
Sure. It looks good.
Reply #226 on:
May 24, 2010, 07:43:55 PM »
JL Audio TR690-TXi (deck)
JL Audio TR600-CXi (front)
I'm looking to go with these speakers for my car (stock HU).
I'm thinking these will be powered fine by the OEM HU. Am I correct?
I believe the front ones need some sort of adapter (according to Crutchfield) but the rear can be popped right in. How would I know what kind of adapter to get since I can get the speakers for about $40 less on eBay.
Reply #227 on:
May 24, 2010, 08:41:41 PM »
They're made by Metra or Scoche and they're specific to our Accords. You can find them on eBay too.
Reply #228 on:
May 24, 2010, 11:12:39 PM »
Is this what I'm looking for?
http://cgi.ebay.com/Metra-82-7803-Speak ... 2ead3fa179
Or am I looking for speaker connectors?
http://cgi.ebay.com/Metra-72-7800-Honda ... 414efd61fc
Thanks in advance.
Reply #229 on:
May 24, 2010, 11:41:10 PM »
You need speaker harnesses regardless of the speaker like the ones in the link. As for the speaker adapter, I needed a one inch spacer because of the size of my magnet. I assume you will need the same. I just got a generic brand and fit at Circuit City, when it was still around, and they worked fine. I believe they were about $20.00. Hope this helps.
Reply #230 on:
May 24, 2010, 11:47:24 PM »
Quote from: "wtcii"
So basically I will need both? I won't mind trying those adapters for like $10...
Reply #231 on:
May 25, 2010, 12:01:40 AM »
Well, I don't know. I can't really tell what those adapters do. Why do you think you need adapters? It should be pretty simple, 6.5" speaker replaces 6.5" speaker. I'll just let the expert answer so it'll be certain.
Reply #232 on:
May 25, 2010, 07:41:58 AM »
The speaker wire adapters will be helpful, but you can just cut off the old adapters and run bare wire. As for the speaker adapters, you may want to make sure they're spaced out so the magnet clears.
Reply #233 on:
June 15, 2010, 12:33:47 PM »
any idea of the quality of JL Audio speakers? I know their subs are great.
considering different options for my build...
Edit: and which series of their speakers is the best bang for the buck?
Reply #234 on:
June 15, 2010, 01:35:33 PM »
Their speakers aren't half bad actually. Honestly, go listen to them and make your decision based on what sounds best to you within your budget.
Reply #235 on:
June 15, 2010, 02:06:53 PM »
No store sells them that know of
I'll figure something out.
Reply #236 on:
June 15, 2010, 02:09:02 PM »
Go to their website, look for an authorized dealer near you, and ask them to listen to the speakers you want to buy.
Reply #237 on:
June 15, 2010, 02:29:22 PM »
is it bad to mix brands of speakers? im sure it is, i have infinity Kappa in back and maybe gona put apline speakers that come with amp in front, i do have kappa for fronts, just have to cut oem door grill out to make them fit
kappa has cross over on each speaker to separate lows and highs and send them to tweaters and midrange speaker,
also what about disconecting/removing oem tweaters? i heard that rubs power to regular speakers
Reply #238 on:
June 15, 2010, 02:50:59 PM »
It's not going to kill anything to use different brands of speakers. The only people that care about that are judges.
As far as your stock tweeters go, you may want to disconnect them if you're not using them. They don't really "rob" power because they don't need much power.
Reply #239 on:
June 15, 2010, 04:24:29 PM »
found other amps with speaker level inputs (kinda looks like most 4 chanel amps have this feature.)
http://www.pioneerelectronics.com/PUSA/ ... /GM-D9500F
http://www.crutchfield.com/p_130GM6400F ... tml?tp=115
http://www.crutchfield.com/p_136J23204/ ... tml?tp=115
15
16
17
18
43
