August 06, 2026, 10:09:09 PM
Pages: « First < Previous 1 ... 12 13 [14] 15 Last »   Go Down
Author Topic: Metra Upper dash kit  (Read 116547 times)
« Reply #195 on: February 01, 2013, 03:56:59 PM »
Alright. I wasn't sure if this kit used the 2 screws at the bottom.
« Reply #196 on: February 02, 2013, 12:58:20 AM »
damn it! if only they send u the email a few days earlier. I took out my H.U and moved some of the stuff around.... Maybe I will add that USB cable for easy access like you suggested Tim. Sigh... Maybe I'll update it in a year. lol My H/U is always on with a/c off (i hope)
« Reply #197 on: February 16, 2013, 04:33:22 PM »
I got a question does your unit blow cold air when it is set to 70+? Mine randomly blows cold air and then hot air and then cold air. Pissing me off when I was driving and it was 20 degrees
« Reply #198 on: February 18, 2013, 08:30:38 AM »
I keep mine on 78-80 and it always blows hot air.  To be honest I haven't even tried the AC yet.
You did the learn procedure when you installed the kit right?  I can email you the updated firmware if you want to try that.
« Reply #199 on: February 18, 2013, 11:42:47 AM »
Let me email Metra and see what they say. I am pretty sure that I did the learning method correct, but I had my car unplugged so many times. Maybe that effected it?
« Reply #200 on: February 18, 2013, 01:20:25 PM »
I don't think I ever redid it after the first time, even after removing the kit from the dash.   Interested in seeing what Metra has to say about it.
« Reply #201 on: February 22, 2013, 10:53:28 AM »
they sent me a firmware update. So lets see how that goes.
Here is the update if anyone needs it
http://axxessinterfaces.com/webxxpress-ezp-15.html
« Reply #202 on: February 22, 2013, 02:01:11 PM »
 If it works I guess I'll bite the bullet and update mine too.
Check to see if you can turn the HVAC on just by pressing the defroster button after you do the update.  I want to see if the update they sent me is included in what they sent you.
« Reply #203 on: February 22, 2013, 04:39:57 PM »
I will let you k now how it goes. I took the whole unit out just to put the USB cable in. Dropped 2 of those white stupid clips!!!! so its not sitting flush anymore... Need to find replacement since I couldn't dig them out...
« Reply #204 on: February 22, 2013, 09:25:30 PM »
Is it a mini usb or micro usb connection on the back of the HVAC?
« Reply #205 on: February 22, 2013, 10:33:21 PM »
micro B USB. got it to install the firmware into my laptop. After you use their installer you must go to C:program/bootloader/usbmicro and install the firmware for the unit. It doesn't install by itself which is really dumb. After that you start the program click update, plug in your usb, and the climate LED will turn red. Takes less then 1 min to install.
Mike I haven't tried with the front defroster, but its no go for the rear defroster for sure. Unit has to be on for the rear to turn on.
« Last Edit: February 22, 2013, 11:45:22 PM by thisaznboi88 » Logged
« Reply #206 on: February 23, 2013, 01:06:29 PM »
okay I tired turning the front and rear defroster while the unit was off. No dice. It has to be on auto for you to have them work. I hope that clears up your question
« Reply #207 on: February 25, 2013, 08:44:13 AM »
This is why I hate pulling it out.   If you still have your oem cubby, it uses the same white clips so you can reuse those.
Was the heat problem fixed?
« Reply #208 on: February 25, 2013, 02:05:56 PM »
I don't have my stock radio or cubby and they don't sell spare parts.... lol
Heating problem was fixed after update and reprogramming. Not sure which one did it, but it works now.
« Reply #209 on: February 26, 2013, 08:03:31 AM »
Here is the part number for the white clips for the oem cubby that fit.   90666-SDA-A01
http://www.hondapartsunlimited.com/oem-part/honda/accord-parts/2007/4dr-ex-v6/ka5at/interior-bumper/instrument-panel-garnish-passenger-side/clip-snap-fitting-po-natural/90666-sda-a01
Pages: « First < Previous 1 ... 12 13 [14] 15 Last »   Go Up
