June 17, 2026, 05:20:34 AM
Laggy VTEC Engagement
Topic: Laggy VTEC Engagement (Read 22804 times)
September 21, 2012, 10:07:49 PM »
I know that I've been a ghost around here for awhile, sorry about that. I've been so busy with school and shit.
Anyways, I've already talked to Tim about this a couple times, but I thought I'd make a thread so that the information is out there. I noticed that the VTEC engagement at 2,200RPM is very delayed (VTEC did not just kick in, yo!). It's to the point where it makes the ride uncomfortable, because when I accelerate from a stop and get up to 2,200RPM, the car jerks as if it lost a substantial amount of torque. At that point, the car loses about 100RPM, and then continues to rise normally. I definitely don't recall it acting like this on my 2005.
In regards to oil, I've checked it, and the levels were perfectly normal. I've had this happen for awhile now. I used to run Mobil Super 5000 5W30 with a Purolator PureONE filter, but I recently switched to Valvoline SynPower 5W30 and the same filter, and it made no difference. I also have never gotten a CEL. I'm pretty much clueless right now.
Thanks.
Last Edit: April 01, 2013, 08:16:02 PM by Jeff
Re: Laggy VTEC Engagement?
September 22, 2012, 12:09:57 AM »
It could be a few things. You may want to check your VTC filter and the filter on the VTEC solenoid. Another issue could be that it could be a bad connection on your VTEC solenoid or VTEC pressure switch, or even a bad switch or solenoid. If you need me to send you one, I have a few extras lying around.
September 22, 2012, 01:30:19 AM »
I'll definitely have to take a look. Where can I access said filters?
September 23, 2012, 09:19:09 AM »
I'll help you out later tonight when I get home Jeff. Either that, or shoot me a text.
September 27, 2012, 08:46:11 PM »
I was going to upload the pics Tim sent me, but I lost them when doing shit to my phone. Here's an illustration instead.
#11 is the VTC filter itself, while #7 is the VTC solenoid (correct me if I'm wrong, Tim).
I'm going to first check on the VTC filter, and clean if necessary. That'll require removing the serpentine belt, moving the P/S pump, and removing the auto tensioner. From there, if I'm still having this issue, I'll look into the solenoid itself.
Thanks for the help Tim.
September 28, 2012, 10:06:32 AM »
Yes Jeff. You are correct. #11 is the VTC filter and #7 is the VTC solenoid (aka spool valve). Also, #5 is the VTEC filter. That's a lot easier to get to. You may want to take that off and make sure it's clean too.
Re: Re: Laggy VTEC Engagement?
September 28, 2012, 10:09:57 AM »
Where does that whole #4 area go? I'll take a look at that filter as well.
September 28, 2012, 10:21:18 AM »
It's bolted on to the back of the head above the oil filter. That's the VTEC solenoid and pressure switch.
eagonzalez2013
January 06, 2013, 12:14:23 PM »
wow thats crazy i just found a brand new vtc filter and vtec filter in my garage, i guess i should replace the old ones then
eagonzalez2013
January 06, 2013, 12:19:26 PM »
ill actually save them for another time because my vtec is not laggy yet! maybe later down then road when i add some mods to the car but its nice to know i have these around
January 06, 2013, 11:29:17 PM »
No need to replace if everything is working.
eagonzalez2013
January 07, 2013, 10:52:28 PM »
but wouldnt the filters go through wear after being there for 145k miles?
January 07, 2013, 11:07:37 PM »
It's a metal screen with a rubber gasket. I have't heard of any cases where anyone needed to replace them because they were worn. You're free to replace them if you want. I just don't think it's necessary if everything is working fine.
January 07, 2013, 11:14:02 PM »
I checked the VTEC solenoid filter at about 93k miles, and it was spotless. I haven't had time to check the VTC solenoid filter, but I'm sure it's just as fine.
I've been kind of living with the lagginess for now. I just don't have the time with school and all.
eagonzalez2013
January 21, 2013, 11:04:31 PM »
yea well I think i kinda jinxed it and im probably experiencing some lag
. Because now when i get to a stop and suddenly accelerate hard passing 2,500 rpms, My car jerks before i even get to 50mph or 3,000rpms. so then when that happens i freak out and let go of the acceleration because i feel like something is going to break. Anyways my car is still stock all i have done is fixed my fans, which now they work perfectly fine and ive also replaced my IACV valve with a barely used one. So the car is working fine except for that jerk it does i cant even speed off ill have to check my oil levels and transmission fluid and if that doesnt work ill also check my vtec filters. Any suggestions you guys?
