April 27, 2026, 09:59:18 AM
Brakes
Pimping out the stock brakes (log thread)
Topic: Pimping out the stock brakes (log thread) (Read 12176 times)
March 30, 2012, 11:24:00 PM »
Since I had to get the Acura RL calipers powdercoated, I decided to overhaul my entire braking system. This means new (re-manufactured) rear calipers, new rear caliper brackets, and stainless steel lines front and rear.
Seems like no matter how well I seem to prep the calipers for high-heat epoxy caliper paint, they will start to chip and flake after one Michigan winter. So I decided to get the calipers and brackets powder coated. Before I sent them off, I decided to get rid of the casting marks. It may seem a little pointless, I figured I'd go a little further to pretty up the brakes.
Rear caliper bracket as it comes from the package
After Dremeling down the high spot
Then I used a palm sander with a 40 grit disk and finished off with a sanding block and 400 grit paper
Also decided to smooth the tops
Calipers as they came out of the box
One done compared to rough
Brackets and calipers before being dropped off
RL Calipers stripped of their "ACURA" logo
Re: Pimping out the stock brakes (log thread)
March 30, 2012, 11:28:22 PM »
While at the powder-coater, we took the RL calipers apart. This meant blowing out the pistons with compressed air and disassembling the two halves. After the pistons were taken out the rubber seals came out very easily. Acura wants around a $100 bucks for a rebuild kit but we were able to salvage all the rubber gaskets. Sorry, I did not take pictures as my hands were filthy.
I will post more pics as they come from the PC guy and more from me as I get them back.
Re: Re: Re: Pimping out the stock brakes (log thread)
March 31, 2012, 03:21:50 AM »
Quote from: Milan on March 30, 2012, 11:28:22 PM
nice! Its a bit if work, but its all in the details!
March 31, 2012, 03:36:53 AM »
March 31, 2012, 04:07:15 PM »
Stupid question but, I've been looking at the RL caliper mod. What are the wheel clearance requirements, and less involved but, more fitting to your thread what color are you going with?
March 31, 2012, 10:51:40 PM »
Any wheel that will clear the TL Brembo calipers will clear the RL caliper but a 17" TL will require you to move the wheel weights inboard more to prevent them from being rubbed off by the caliper. This is primarily the reason I went with the 18" A-spec wheel. Concave and wheels with lips are not a good mix with a BBK.
The color I'm going with is silver metallic.
March 31, 2012, 11:59:02 PM »
Nice I'm thinking Black Chrome for mine... Long way to go though need to source some wheels first.
April 25, 2012, 10:35:38 PM »
Nothing was left bare. Rear calipers were taken apart by a master tech and full powdercoated.
April 26, 2012, 09:19:36 AM »
Pretty.
April 26, 2012, 09:23:48 AM »
Those calipers look awesome. You're making me want to do the RL caliper mod, but I still need to get my Legend calipers installed first. Maybe down the road I'll be able to get larger wheels and complete this mod. I'm not going to lie, all four sets of pads on my car still have a good amount of beef left on them, but my braking performance is still absolutely terrible.
April 26, 2012, 12:14:20 PM »
Looking good
April 26, 2012, 12:53:32 PM »
Very pretty indeed.
April 26, 2012, 11:51:35 PM »
They look like shit in person!!
