August 17, 2026, 03:21:08 PM
Valve Cover Question
Topic: Valve Cover Question (Read 11198 times)
James_P
March 12, 2012, 10:04:00 PM »
Hey guys, I was 100% sure on where to post this question but i figured stock motors was a good choice. Please move it if it is in the wrong form, but my question is what is the torque specs on the valve cover bolts, and what is the order? Btw the motor is a k24a4,
thanks a bunch!
Re: Valve Cover Question
March 13, 2012, 12:42:08 AM »
Here you go.
James_P
March 13, 2012, 08:30:55 AM »
Thanks so much!
March 13, 2012, 09:32:58 AM »
No problem!
Re: Re: Valve Cover Question
March 13, 2012, 10:04:52 AM »
There's a torque spec for the valve cover? I've never torqued the valve cover down, unless you count German torque spec as an actual spec.
March 13, 2012, 12:59:01 PM »
If you think about it logically, you want to be sure to torque it properly so you don't damage the gasket an have an oil leak. Its a rubber gasket, so it's easy to over tighten.
Re: Re: Re: Valve Cover Question
March 13, 2012, 04:54:52 PM »
Quote from: timot_one on March 13, 2012, 12:59:01 PM
True. I have a delicate touch though.
March 14, 2012, 08:51:40 PM »
I have over tightend the valve cover bolts on Piero's ride before and snapped one of the bolts! So be really careful when tightening.... we had to special order the damn things and it came 2 days later.
March 14, 2012, 09:28:10 PM »
You probably coulda gotten some from me. I have a couple of sets of this bolts from the 4 different cylinder heads that I have.
March 14, 2012, 09:34:15 PM »
This was a while back Tim. I remember Billy telling me about it.
March 27, 2012, 11:40:52 AM »
Quote from: CrackerTeg on March 13, 2012, 04:54:52 PM
smh, can be taken in so many different ways Z....hm.... looks like i did it right when i replaced my gaskets
March 27, 2012, 03:52:44 PM »
That was the point.
