August 18, 2026, 03:25:27 PM
Royal Purple (ATF and Engine Oil)
Topic: Royal Purple (ATF and Engine Oil) (Read 7202 times)
Moessteezy
Names Moe
August 10, 2011, 11:34:45 PM »
About this Product:
Max ATF is a synthetic, high-performance, automatic transmission fluid. Its low co-efficient of friction and high film strength help to dramatically reduce heat and wear. Additionally, Max ATF is more oxidation stable than other transmission fluids for longer fluid life.
About this Product:
Royal Purple Motor Oil delivers superior protection and improves performance in four-cycle gasoline and diesel engines. It increases horsepower and torque, saves fuels and reduces heat, wear and emissions. It has unsurpassed oxidation stability that allows for extended oil drains and fewer oil changes, which saves you time and money and reduces the impact on the environment.
^^ any thoughts on these two products?
im going to be doing my oil changes soon and was wondering should i use these two products, thanks.
Re: Royal Purple (ATF and Engine Oil)
August 11, 2011, 05:40:22 AM »
I'd suggest staying with Honda transmission fluid...
Re: Re: Royal Purple (ATF and Engine Oil)
August 11, 2011, 06:29:51 AM »
Auto or manual?
August 11, 2011, 06:46:21 AM »
Quote from: CrackerTeg on August 11, 2011, 06:29:51 AM
Auto or manual?
ATF = Automatic Transmission Fluid... DUH!!!!
August 11, 2011, 07:03:05 AM »
Reading pwns me. Shut the fuck up Mike. Its early and I haven't had my coffee yet.
August 11, 2011, 07:21:30 AM »
It's early for me to silly. Back on topic the Honda Fluids use some synthetic additives that other fluids do not. They are designed specifically for use in Honda Transmissions.
Moessteezy
Names Moe
August 11, 2011, 08:18:29 AM »
Quote from: Mike on August 11, 2011, 07:21:30 AM
dope
so what about the royal purple motor oil?
August 11, 2011, 09:06:06 AM »
It has some benefits when compared to other synthetics but, IMO it doesn't justify the tremendous cost.
August 11, 2011, 10:53:34 AM »
I've gotta agree with Mike on the RP engine oil. The cost doesn't really outweigh the benefits. I still use dino oil with my motor, and it's a bit more "built" than others.
August 11, 2011, 08:41:00 PM »
D4 works wonders for the v6 tranny. Maybe it will do the same for yours.
