June 17, 2026, 06:42:49 AM
Random ass car whoring thread.
179
180
181
182
191
Topic: Random ass car whoring thread. (Read 1101642 times)
Re: Random ass car whoring thread.
Reply #2685 on:
November 19, 2013, 08:45:41 PM »
As Tim for his parts and build a Frank K20/24 motor. Way less work and you get to use Kpro. Flashpro can't touch that.
Or go Jackson Racing S/C
Last Edit: November 19, 2013, 08:49:23 PM by thisaznboi88
Reply #2686 on:
November 20, 2013, 08:08:36 AM »
Quote from: Jeff on November 19, 2013, 06:26:28 PM
I have a better idea. Hunt down the fuckers that are storing the HSV-010GT and steal the V8 from that. Then you'll have a man's swap.
No.
Quote from: Rich01 on November 19, 2013, 07:48:52 PM
You would need and upgrade in mounts also and maybe sub-frame and/or bushings. I know some are the same across, but some suspension components are J specific for the added weight. Have you looked at the cost of FI with re-sleeving your current block?
Bushings, sub frame and aftermarket suspensions transfer over. The mounts are factored into that $1k buffer on top of the cost of the engine and other things from LKQ. Re-sleeving my current block leaves me with no vehicle for awhile. I can't afford that. Going FI also costs a lot more than a J swap. If I were to get a "kit" (I hate that word) and modify it to work, I'm already looking at $4k not including engine management. Sure, I could piece it all together with good parts but the turbo would have to get rebuilt regardless of what the previous seller says if I were to go the used route. A new turbo goes anywhere from $1k to $2k depending on the turbo I select. That also goes into the realm of not being OEM reliable.
Quote from: gargantula99 on November 19, 2013, 08:05:18 PM
Just sell you car and buy mine. Settled.
No. Your shit is cursed.
Quote from: thisaznboi88 on November 19, 2013, 08:45:41 PM
See my response to Rich above.
Reply #2687 on:
November 20, 2013, 08:11:36 AM »
Your wife wont let you buy tires but will let you spend more money on this swap? I'm just saying.
Last Edit: November 20, 2013, 08:15:36 AM by slipkord
Reply #2688 on:
November 20, 2013, 08:26:43 AM »
My shit ain't cursed, you fucker!!! Take it back!!
Re: Re: Re: Random ass car whoring thread.
Reply #2689 on:
November 20, 2013, 08:37:25 AM »
Quote from: gargantula99 on November 20, 2013, 08:26:43 AM
I hadn't thought of the curse.
Reply #2690 on:
November 20, 2013, 08:42:11 AM »
Quote from: CrackerTeg on November 19, 2013, 03:26:56 PM
A wrecked 6 speed TL is hard to find out here so that's difficult to say. LKQ has the J30 engine for about $500. Not sure if that's including accessories. Transmission is another $500. ECU out of an 05 6 spd Accord is about $300. The engine harness I'm assuming is about $300 but I haven't gotten a definitive answer on that. Other odds and ends being a timing belt, compression and leakdown, new clutch and single mass flywheel, shifter box, etc is maybe another $1k for the miscellaneous shit and I'm shooting a bit high. All labor done by me at school. A k24a2 from LKQ is roughly $1200. Transmission is approximately $800 (LKQ has none available as of this post). ECU about $200 plus all the other jazz I mentioned previously.
J30a4 swap=$2600ish
K24a2 swap=$3500ish
Drive to Paul leave car. Pay money, pick up car the end?
Re: Re: Re: Re: Re: Random ass car whoring thread.
Reply #2691 on:
November 20, 2013, 09:36:54 AM »
Quote from: slipkord on November 20, 2013, 08:11:36 AM
Reasoning won that. The winters are on there right now. This swap isn't going to happen for awhile and she knows I'm chomping at the bit to do something big.
It is and I won't.
Quote from: Mike on November 20, 2013, 08:42:11 AM
Take the cost of the parts and triple it. No thank you. I'm perfectly capable of taking it on myself and have the means to do it. If I were doing the bigger mods he's known for, definitely.
Reply #2692 on:
November 20, 2013, 09:52:15 AM »
It's not cursed!!! I'm offended that you say that. I actually haven't started my car in like three weeks. I should start that bad boy up. It needs a wash. Maybe Saturday.
Reply #2693 on:
November 20, 2013, 10:03:47 AM »
3 weeks!!! D:
Reply #2694 on:
November 20, 2013, 10:31:26 AM »
Quote from: gargantula99 on November 20, 2013, 09:52:15 AM
How many times have taxis hit it? And not in the same spot either. Cursed.
Reply #2695 on:
November 20, 2013, 11:36:47 AM »
Yeah, well your car has gremlins.
Reply #2696 on:
November 20, 2013, 11:43:11 AM »
One gremlin and it was caused by your stupid city.
Reply #2697 on:
November 20, 2013, 12:43:02 PM »
I think your car senses that you wish to replace it, so it's not caring as much about it's well being. You made it depressed! It's hurting itself!
Reply #2698 on:
November 20, 2013, 01:08:48 PM »
Nelson's?
Reply #2699 on:
November 20, 2013, 01:13:16 PM »
Yes.
179
180
181
182
191
