April 27, 2026, 05:11:41 AM
Pages: « First < Previous 1 ... 98 99 [100] 101 102 ... 191 Next > Last »   Go Down
Author Topic: Random ass car whoring thread.  (Read 1060435 times)
« Reply #1485 on: March 19, 2012, 03:06:39 PM »
Aint shit till they hit triple dog dare
status
GOMD
status pfffft.
« Reply #1486 on: March 19, 2012, 03:46:07 PM »
I triple dog dare you.....
-Alec
« Reply #1487 on: March 19, 2012, 03:49:02 PM »
I'm not getting an lx accord if I'm getting dared ill get a vette lol
« Reply #1488 on: March 19, 2012, 04:01:53 PM »
Don't hate on the SSM 05 LX Accord sedan fucker!
« Reply #1489 on: March 19, 2012, 04:54:52 PM »
Hahahaha!!!!!!
« Reply #1490 on: March 19, 2012, 05:49:16 PM »
I dare you to make a decision, buy a fucking car and keep it for longer than a month.
status
GOMD
status pfffft.
« Reply #1491 on: March 19, 2012, 06:22:40 PM »
shit, thats like asking kaley cuoco to marring you and her saying yes.
-Alec
« Reply #1492 on: March 20, 2012, 08:50:52 AM »
I just figured something out that will narrow my car search. My life is so cookie cutter, its the same everyday, I need a car that will be balls out fun, I miss my s2k, I could easily have a shityy day and put the top down and hammer thru the gears and forget all the bullshit. I need something that will put a smile on my face so I can forget the day....ideas?
« Reply #1493 on: March 20, 2012, 08:53:24 AM »
...and the insanity continues.  Huh?
« Reply #1494 on: March 20, 2012, 09:04:54 AM »
It will never end, until I find a car
« Reply #1495 on: March 20, 2012, 09:12:43 AM »
I don't think that's going to happen.  Prove me wrong.
« Reply #1496 on: March 20, 2012, 09:16:36 AM »
Some car ideas might help
Rushzer0 pfffft.
« Reply #1497 on: March 20, 2012, 09:32:00 AM »
Buy a vette!
If you win the lottery buy this Cheesy
http://www.jaydeequantum.com.au/images/index.html
SPECIFICATIONS
Performance
Acceleration: 0-100 km/h (0-62 mph) 2.6 seconds*
Top Speed: 292km/h (180 mph) *
Braking distance: 30.5m (100-0 km/h)
Lateral G-force: 1.5+ G
BHP per Tonne ratio: 1200 bhp/1 tonne *
(* performance figures for the Quantum 700 engine option)
Aerodynamics
Downforce is adjustable via multi element wings
Flat underside of chassis with Venturi tunnels at rear of chassis/body
Chassis
Carbon fibre honeycombe floor (partial tub) with integrated removable fuel tanks.
Aircraft Alumimum chassis intergrated into the carbon fibre floor.
Front and rear suspension: Double wishbones, multi adjustable Ohlins or WP PDS shock absorbers via pushrods.
Fully machined aluminium uprights.
Jaydee knife adjustable anti-roll bar.
Engine
Our Jaydee Quantum is customer configured with optional power outputs, to suit your application.
Your choice of power level. (Higher power Quantum's can reduce power with a dashboard adjustment for street driving) From the Jaydee Quantum 375 ranging to the fully optioned Quantum 700.
Our engines are designed and built in-house using the Honda K series iVtec engines as a base platform. The K series iVtec engines are installed in most current Honda 4 cylinder production cars, and range in tune and capacity from the Accord Euro to the Civiv Type R.
Thus our engine choice ensures shelf components are available for the maintanence and servicing, and importantly the servicing is simple. This philosophy is in stark contast to the complex servicing requirements of most modern supercars.
Transmission
All options are 6 Speed close ratio gearboxes.
The standard trnasmission is a carbon fibre syncomesh 6 speed gearbox with a torque sensitive limited slip differential. This gearbox combination has proven strength, and gives impressive shifting while noise output is at OEM levels.
We have specially developed a transverse mounted sequential paddle shift gearbox* combined with a torque sensitive limited slip differential. This gearbox has custom ratios available for each gear, as well as the overall final drive ratio.
*optional
Steering
Rack and pinion steering. 1.6 turns lock-to-lock is standard. (Optional ratios avalable)
Brakes
Front brakes: Ventilated steal discs Ø 280 mm, 20.5 mm wide.*
4 piston light alloy Wilwood calipers
Rear brakes: Ventilated ceramic discs Ø 280 mm, 20.5 mm wide.
4 piston light alloy Wilwood callipers
* Optional larger front discs for heavy duty track work.
Wheels
TR Motorsprots alloy wheels with 5 stud locking*
Front: 17 ” x 8 ”
Rear: 18 ” x 9.5”
*Optional customer specified wheels and colours.
Tyres
Dunlop DZ03G road legal tyres with a choice of compounds
Dimensions
Total length: 4493 mm
Total width: 1796 mm
Total height: 1146 mm
Ground clearance: 100 mm (3.9”)
Dry weight: sub 600kg (1300 lbs)
« Reply #1498 on: March 20, 2012, 11:21:47 AM »
Jer, buy youself another s2k with an installed ZJ administrator.
« Reply #1499 on: March 20, 2012, 11:23:34 AM »
ZJ admin??
Pages: « First < Previous 1 ... 98 99 [100] 101 102 ... 191 Next > Last »   Go Up
