November 05, 2026, 08:09:10 PM
Brakes
Brake Fluid Flush
Topic: Brake Fluid Flush (Read 31373 times)
Re: Brake Fluid Flush
May 09, 2011, 12:56:02 PM »
ahhh fucken A my bleeder valve are stripped... So I bought speed bleeder valves. That way I can do it on my own... Piss me off though.
jobata23
May 09, 2011, 10:51:44 PM »
that's good I saw this thread I will be doing mine as well. so the sequence are correct from the top?
May 09, 2011, 11:39:43 PM »
Yes it is. Left front, right front, right rear, left rear.
AZcaveman
May 19, 2015, 10:28:10 PM »
When only replacing front pads/rotors, should i bleed the rear as well? Or is ok to only do front?
May 23, 2015, 11:18:47 AM »
You are suppose to bleed the whole system. That way you don't get any back flow from the old brake fluid mixing in with the new brake fluid.
