June 19, 2026, 11:14:27 AM
Stock Cam
Topic: Stock Cam (Read 18968 times)
tennis
Re: Stock Cam
January 12, 2011, 08:17:48 PM »
something i thought about.. if the brian crower
stage 2
cams have a lift of 410"/.410" then y do the skunk2
stage 1
cams have a lift of 0.449”/0.449”. on the brian cower site it says for the stage 2 cams that the cam
"Requires kit BC0050"
with a lift of .410.. then y does the skunk 2
stage 1
with a
.449
lift only say recommends..if i have misunderstood something then please please correct me.. but something doesnt seem right
fatbastard
Re: Stock Cam
January 12, 2011, 08:27:43 PM »
Quote from: tennis on January 12, 2011, 08:05:11 PM
2nd he said if the paper that came with the cams said "Valve train upgrade is recommended" not "required" then the cams that i was sent were not stage 1 cams.
as per skunk2, stage1 TUNER cams don't need valvetrain upgrades. maybe you got the PRO cams?
-- Charles --
2005 Honda Accord 2.4L sedan
2011 Subaru STi sedan
tennis
Re: Stock Cam
January 12, 2011, 08:29:46 PM »
unless they sent me pro cams in a box with the paperwork for stage 1 cams if they did that then yes.. but on the website they dont have pro k series cams..... also read my last post the one above yours... y would the stage 2 brian cower cam need springs when it has less of a lift then the skunk 2 stage 1 which doesnt require one
Last Edit: January 12, 2011, 08:38:32 PM by tennis
fatbastard
Re: Stock Cam
January 12, 2011, 08:46:33 PM »
brian crower cams have more duration.
-- Charles --
Re: Stock Cam
January 12, 2011, 08:54:29 PM »
Have you called Skunk2 about this yet? I bet they can provide a little bit of insight when it comes to needing a valvetrain upgrade. My guess is that the installer fucked up and the timing was off. If other people have used Skunk2 Stage 1 cams with the OEM valvetrain, and you got valve to piston contact, then it's either the install or you were sent the wrong cams by Skunk2.
tennis
Re: Stock Cam
January 12, 2011, 09:13:55 PM »
i got the cam from chris off of gen7accord... he was selling them almost half price.
Re: Stock Cam
January 12, 2011, 09:29:58 PM »
He's running them in his car too. Something isn't right here. Sounds like the install.
fatbastard
Re: Stock Cam
January 12, 2011, 09:38:53 PM »
yeah as per skunk2, even stage3 cams won't have clearance issues with stock engines.
-- Charles --
Re: Stock Cam
Reply #23 on:
January 12, 2011, 11:18:54 PM »
The only reason why you would have valve to piston contact is if the timing was off. You can advance your intake cam up to 30º on a K24 Accord. The TSX K24A2 comes with a 25º cam gear, but you can advance your intake cam up to 45º without valve to piston contact. One reason for upgrading your valvesprings and retainers is to be able to accommodate the additional lift that most aftermarket cams give you. My guess is that your installer fucked up and the timing was off enough to cause the damage or another thing that it could be is that your timing chain tensioner failed and your chain skipped a few teeth. Usually, your timing chain tensioner doesn't fail immediately. Usually it will fail over time with aftermarket cams.
fatbastard
Re: Stock Cam
Reply #24 on:
January 13, 2011, 02:46:24 AM »
is it then recommended to replace the timing chain tensioner at set intervals when aftermarket cams are installed?
-- Charles --
Re: Stock Cam
Reply #25 on:
January 13, 2011, 08:18:57 AM »
No. It's suggested that you replace the timing chain tensioner with a stronger aftermarket unit. There are 3 companies that make them. Toda, Skunk2, and Hybrid Racing. Hondata uses the Skunk2 timing chain tensioner on their 2 k powered land speed cars. You can also get a discount from Skunk2 if you already own a set of their cams. If it were me, I'd only use the Skunk2 or Hybrid Racing tensioners. I don't know a lot about the Toda one, because I haven't researched it. I do know that the Skunk2 and Hybrid Racing timing chain tensioners are not remanufactured OEM units, but are completely redesigned and new units.
tennis
Re: Stock Cam
Reply #26 on:
January 16, 2011, 02:40:36 PM »
ok well as of right now i dont have access to the motor and neither does the mechanic... bt he said that he would compencate me 300 for the motor and 300 for the cam
